    MUSIC
    Themes & Interface
    music
    • Big_B
      Big_B last edited by
      I have Recalbox on a Rpi3.
      How do I fix it, so my menu music doesn't begin until my splash screen is finished?
      This is bugging me. Any help would be appreciated 🙂
      • Gaetan
        Gaetan Theme moderator @Big_B last edited by
        @big_b hi, it's not possible. The music starts when ES is loaded and there is no way to change that.
        As an alternative, if you got one music per system, you can delete the one where you Recalbox is starting or with a software, add a silence at its begining.
        Big_B 1 Reply Last reply Reply Quote 0
        • Big_B
          Big_B @Gaetan last edited by
          @gaetan OMG I'm dumb LOL. I never thought of deleting the music for the "Favorites" section, which is what mine starts on. Thanks, I'll try that.
          How do I add a silence at the beginning?
          • Gaetan
            @big_b to add silence maybe you can use audacity ? But I'm not sure since I didn't do it
            • Big_B
              @gaetan Oh ok. I'll look into it.
