    Child Friendly ES Possible?
    Your recalbox
    child friendly possible
    3079
    • tdelios
      tdelios last edited by
      https://github.com/retropie/retropie-setup/wiki/Child-friendly-EmulationStation
      Is there anyway in Recalbox to have a Child Friendly ES in order to not only to prevent children from playing specific games (unless they enter the parent password), but also to prevent them from accessing the folder structure of Recalbox's OS through a network connection?
        Substring @tdelios last edited by
        @tdelios nope, there is not. You could donthe trick with a usb key that wouldnhave your roms, and if you remive it, only kids games on the sd
        tdelios 1 Reply Last reply Reply Quote 0
        • Dragu
          Dragu Banned last edited by
          @tdelios said in Child Friendly ES Possible?:
          But you also dont have this on television set, so if Trump appears, kids have no other solution than to hide under the bed. 🙂
          • tdelios
            tdelios @Substring last edited by
            @substring .. is there at least a command line I can run to make the 'roms' folder invisible..
            I've been finding that they have been deleting games from the consoles sub-folders
              @tdelios activate bartop mode at least to prevent such problems
              • tdelios
                @substring how can I active Bartop Mode? Is it in the ES menu?
                • Gaetan
                  Gaetan Theme moderator @tdelios last edited by
                  @tdelios you can find it here :
                  https://github.com/recalbox/recalbox-os/wiki/Configuration-recalbox-pour-Bartop-Born-Arcade-(FR)#d---configuration-du-menu 🙂
