    How to align the system to display correctly on the screen
    cut component
    3093
    • DJMatrix-HU3
      DJMatrix-HU3 last edited by DJMatrix-HU3
      How to align the system to display correctly on the screen?
      I tried the following settings in config.txt
      sdtv_mode=0 ( 0 ,1 ,2 , 3 )
      sdtv_aspect=3 ( 1,2,3 )
      Help??
      alt text
      alt text
      alt text
        Substring @DJMatrix-HU3 last edited by
        @djmatrix-hu3 are you on a crt screen ?
        DJMatrix-HU3 1 Reply Last reply Reply Quote 0
        • DJMatrix-HU3
          DJMatrix-HU3 @Substring last edited by
          @substring said in How to align the system to display correctly on the screen:
          yes
            @djmatrix-hu3 well ... Crt was never really meant to be perfectly aligned ... The only thing you can do is to have fun with overscan manually. Anyway that's a common problem with the pi, not sure you can do much about it
            • DJMatrix-HU3
              @substring will changing overscan settings not working for me would be a raspberry pi 3 bug?
              disable_overscan = 0
              overscan_left = 900
              overscan_right = 600
              overscan_top = 900
              overscan_bottom = 600
                @djmatrix-hu3 the overscan settings do not have an impact in every displays of the pi ... And i think that 3D rendered context is one of those things tbat don't carr about overscan ...
                The only trick left is to go in the system menu of your tv
                • DJMatrix-HU3
                  my tv there is no option for resolution rate
                  Solution for anyone who has this type of problem:
                  edit theme.xml and realign objects according to screen size
                  Thank you for your support @Substring
                    @djmatrix-hu3 use the crt theme at least 😉
