    [Recalbox 9] Thème Mukashi
    Themes & Interface
    theme recalbox 9
    49
    343
    370641
    • Michigen
      Michigen last edited by
      Bonjour 🙂
      Sorry, I don't speak French.
      First time I have to say "wow! Great work"
      I have a question. Is it allowed to download this beautiful theme? I tried to following the link in google drive. But I don't know what I have to do there.
      I also would spend for some great work.
      Best greetings 🙂
      • airdream
        airdream Theme moderator @Michigen last edited by
        @michigen
        Yes you can download it from Google Drive.
        After you need to copy all files in the right folder on you micro SD card or usb drive
        • Michigen
          Hi!
          Thanks for the fast answer. Ok, I'll trying it again later.
          I didn't find the download option. My documents has an option🤔 maybe I have to try it on my computer.
          Thank's alot 😊
          • airdream
            @michigen
            On windows you can easly download it
            You can see below, at th top right of the screen "TOUT TELECHARGER" mean in french "
            Download All"
            • Michigen
              Excellent! Everything worked well. Now, though, I have another problem. Changing the theme keeps my screen black as if I were exiting emulation station. I have downloaded the (Mukashi legacy clear 1080), unpacked and then moved to the path "recalbox / share / system /. Emulationstation / themes". recalbox also shows me the theme in the menu. Then I restarted the Raspberry. After restarting, I changed the theme, the screen turns white with the logo of recalbox, and then hangs up. The screen black, just like I would end emulationstation. Did I do something wrong?
              • Michigen
                I forgot to say that I still use the old version 18.04.20. On a Raspberry pi3. Only if that is a problem.
                • airdream
                  @michigen
                  Yes recalbox 18.04 20 have an issue.
                  You need to change theme by your computer, editing config file manually.
                  It's not a dysfonctionnement of Mukashi, another theme have also the same issue with this old version on recalbox
                  Michigen 1 Reply Last reply Reply Quote 0
                  • Michigen
                    Michigen @airdream last edited by
                    @airdream thx, i found that thread. I'll try this tomorrow. 🙂
                    • Michigen
                      All right 🤩🤩🤩 everything works great!
                      Just one question.
                      I love the vertical wheel version, but in the horizontal version looks the game list with the background better. Is there an update to get the same game list background in the vertical wheel version?
                      • airdream
                        @michigen
                        Oh!! We have stopped Mukashi Fusion (with wheel or vertical band)
                        Maybe @mrseguin will develop it in the future but you need to ask him.
                        • Michigen
                          @airdream great! I'll ask him. That would be great. But is the answer no, i also love this theme in the H. version.
                          Again, thank you very much for this beautiful work.
                          • Gribouille
                            Gribouille last edited by
                            Le thème ne fonctionne plus chez moi avec la 6.1, quand je le choisi et que le pi reboote(il reste bloquer avec l'image des fantômes), il me remet officielle après un certain temps !!
                            System: Rpi 3B+ & Sandisk 32Go & Recalbox 6.1.1
                            Thème: Mukashi 720p
                            Box: NespiCase+
                            Pad : 8BitDo N30 Pro 2
                            Stockage: Disque Dure Externe USB 2To
                            Réseau: WIFI
                            • airdream
                              airdream Theme moderator @Gribouille last edited by airdream
                              @gribouille
                              Bizarre car chez moi le passage a recalbox 6.1 a au contraire amélioré les performances de Mukashi (plus d'écran blanc lorsque trop de systèmes, pas testé la limite cependant).
                              As tu fais une installation propre de la 6.1 ou une mise a jour de la 6.0 vers la 6.1?
                              C'est un Mukashi ancien ou le dernier que tu utilises ?
                              Je remets au cas ou les derniers liens de téléchargements
                              -- Mukashi Legacy Clear 1080
                              -- Mukashi Legacy 720
                              Gribouille 1 Reply Last reply Reply Quote 0
                              • Gribouille
                                Gribouille @airdream last edited by
                                @airdream Oui j'ai refait une installation de zéro j'ai juste remis les bios et les roms et les médias et le thème c'est bien le nouveau !
                                Thème: Mukashi 720p
                                Box: NespiCase+
                                Réseau: WIFI
                                • airdream
                                  @gribouille
                                  J'ai du mal a comprendre pourquoi chez toi ca marche pas. J'ai testé avec un RPI 3B et un RPI 3B+, pour les 2 je n'ai eu aucun probleme avec Mukashi 1080.
                                  As tu essayé d'autres themes pour voir?
                                  Mystère mystère....
                                  Gribouille 1 Reply Last reply Reply Quote 1
                                    Bonjour @airdream
                                    A tout hazard, votre thème a bien ajouté les balises pour les snaps vidéos ?
                                    mrseguin 1 Reply Last reply Reply Quote 1
                                    • Gribouille
                                      @airdream Et c'est le seul thème qui me fait cela, j'en et tester deux ou trois qui eux fonctionne parfaitement !!
                                      Thème: Mukashi 720p
                                      Box: NespiCase+
                                      Réseau: WIFI
                                      • mrseguin
                                        mrseguin Theme moderator @acris last edited by mrseguin
                                        @acris Salut Acris 🙂 Entre openconsoles et ici tu es actif !
                                        Heu ca fait quelques temps que j ai délaissé Mukashi....Balises?
                                        Rajouter dans le xml de Mukashi des lignes concernant les videos ?
                                          @mrseguin
                                          oui effectivement 😄
                                          oui il y a des balises <video> à ajouter dans la gestion de gamelistviews
                                          mrseguin 1 Reply Last reply Reply Quote 0
                                          • Gribouille
                                            Bon cette fois j'ai réussi en l'installant directement sur mon disque dure externe dans le dossier thème alors qu'avant je l’installais via ftp, mais par contre je n'es plus les vidéos sur aucun systèmes 😕
                                            Thème: Mukashi 720p
                                            Box: NespiCase+
                                            Réseau: WIFI
