    BLUE Twin PS1/2 to USB adapter not working with PS2 Dualshock controller
    GamePad/GPIO/USB encoder
    blue ps12 usb adapter ps2
    • fedorterrell
      fedorterrell last edited by fedorterrell
      Hi to all,
      I just bought two blue triangular twin PS1/2 to USB adapters from Ebay. Both are working correctly with the PS1 controller but I'm unable to use my PS2 Dualshock. I tested the PS2 controller with a PS1 console, it's working. When I try to map the PS2 controller in Recalbox, I can only switch the analog switch but I cannot map the buttons since pressing them does nothing.
      What am I missing here ?
      Thanks !!!
      Piotr.
      dh04000 1 Reply Last reply Reply Quote 0
      • dh04000
        dh04000 @fedorterrell last edited by
        @fedorterrell those twin adapters tend to confuse recalbox. Recalbox assumes one usb connection equals one controller.
        • fedorterrell
          Thanks for your answer @dh04000 !
          But Recalbox seems to recognize it as a "Twin USB Joystick". If I plug the two blue adapters I have, RecalBox recognizes 4 controllers... If I map the buttons on the controller plugged in the 2nd USB port, Recalbox configures the 3rd controller. So that all seems logical. The issue seems somewhere else.
