    White screen on Boot
    white boot
    • guzilli
      guzilli last edited by
      Hi, just got a new full HD TV and now everytime i boot my recalbox i just got a white screen. With my old HD Ready TV everything works fine. How can i fix this? and why does this even happen?
        Hello which recalbox version are you using? 3.2.11 or 3.3.0?
        • guzilli
          Im using the newest Beta
          • digitaLumberjack
            Did you set the theme "Zoid" ? If so you should edit the /root/.emulationstation/es_settings.xml and set back the simple_light theme. : <string name="ThemeSet" value="simplelight" />
            • guzilli
              Ah thx, changing back to simplelight did the trick. To Bad that zoid wont work on full hd TVs 😞 I liked that theme a lot more
