    N64 aspect ratio
    Emulator Arcade/PC/Console
    aspect ratio
    • someperson
      someperson last edited by
      I'm trying to play N64 games on my XU4 in Recalbox, and it seems to work pretty well, except for one thing: the games are stretched to 16:9. How can I disable this so I can play N64 games in their original 4:3 aspect ratio?
      • Gaetan
        Gaetan Theme moderator @someperson last edited by
        @someperson you should try first with your tv. I had the same thing and after a while searching for the answer, i just had to change my tv ratio 🙂
        someperson 1 Reply Last reply Reply Quote 0
        • someperson
          someperson @Gaetan last edited by
          @gaetan I'm using a PC monitor for now that has no aspect ratio settings. Even if it did though, that sounds like an annoying workaround, having to adjust it for N64 games and then turn it back for everything else.
          NeeeeB 1 Reply Last reply Reply Quote 0
          • NeeeeB
            NeeeeB @someperson last edited by
            @someperson add this line at the end of the recalbox.conf :
            n64.ratio=4/3 (it works for mupen64plus at least)
            Vieux geek ^^
