    [Theme] Clean Retro
    Themes & Interface
    [theme] clean retro
    41
    81
    80615
    • A Former User
      A Former User last edited by acris
      We’re proud to present you our new Clean Retro theme. It’s been a long time we’ve wanted to make a clean theme so you could browse your collection in style! With the new theme customizer functionality, you can now choose between 5 different system views. Choose the help menu icons depending on the controller you’re using. Choose the system logos according to your country. Beautiful splash screen intro video is included. Non distractive overlays for all systems are included. A custom system list that organize all your systems is included. A custom mix image to scrape your games in high definition. New audio tracks have been added. We also remastered all audio tracks to have consistent audio level between system change. The theme is also fully compatible with any screens like CRT and smaller screens.
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      Mix image for scraping in UXS and gamelist view
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      text alternatif
      Menu match the theme design
      text alternatif
      Changelog
      V1.2
      • Added USA controller for Atari 7800
      • Added Japan system for Master System
      • Updated SVG "console" and/or "consolegame.svg" for 15 systems
      • Updated "icon_empty.svg" and "icon_filled.svg" for Amiga/Neogeo
      • Removed "game.svg" files
      V1.1
      • Fix game list view when there are roms but no "gamelist.xml" file
      V1.0
      • Added 5 system views
      • Added custom system logos
      • Added box art backgrounds from "cleanbg" theme
      • Added splash screen intro video
      • Added custom mix image for scraping with UXS
      • Added custom system list (Arcade, Consoles, Computers, Handhelds, Ports, Other)
      • Added generic crt classic overlay for older systems
      • Added generic crt flat overlay for newer systems
      • Added generic arcade overlay for Arcade system
      • Added per system overlay for each handhelds
      • Added per game overlay for Vectrex games
      • Added per system backgrounds
      • Added per system music tracks
      • Added compatibility for CRT and small screens
      • Modified various xml files from original theme
      Credits
      • Clean Retro - FreemanQC
      • Backgrounds - Niglurion
      • Original Theme - Recalbox
      this theme is compatible with the latest version of RB on Odroid XU4 only.
      DOWNLOAD LINK
      Substring toto421 blaze2051 Maverick23 4 Replies Last reply Reply Quote 6
      • Benny
        Benny last edited by digitaLumberjack
        @deletedaccount Really nice theme 🙂
        • ViRuS-MaN
          ViRuS-MaN last edited by
          i download and try after
            Substring @Guest last edited by digitaLumberjack
            @deletedaccount on a posé une license sur les thèmes recalbox, il faudra la preciser Cf https://gitlab.com/recalbox/recalbox-themes
            Je te remercie de la lire et de la respecter. Dans les grandes lignes : réutilisable sans modification, en citant les auteurs, utilisation commerciale interdite
            A Former User 1 Reply Last reply Reply Quote 0
            • A Former User
              A Former User @Substring last edited by
              @substring Allo! J'ai inclus la license d'origine dans mon readme.txt et j'ai bien lu le passage suivant
              Summary of the license below:
              ALLOWED: - Share and duplicate as it is
              - Edit, alter, change it
              REQUIREMENTS: - Attribution, give credit to the creator
              - Indicate changes to it
              - Publish the changes under the same license
              PROHIBITED: - Commercial distribution
              C'est donc permis de modifier le thème.
              Je ne fais pas de distribution commerciale.
              J'ai cité dans les crédits "Original Theme - Recalbox Team".
              Je ne comprend pas trop ce que j'ai loupé.
              Merci.
              • toto421
                toto421 @Guest last edited by digitaLumberjack
                @deletedaccount Jolie thème simple, basique 🙂
                Petite question car j'utilise également UXS, ou as-tu trouvé ces mix ?
                MikOzzZ 1 Reply Last reply Reply Quote 0
                • MikOzzZ
                  MikOzzZ @toto421 last edited by MikOzzZ
                  @toto421 Pour ceux la je pense que ce sont des styles de scrap perso adapté de FOOLSCREN , mais tu peux avoir le même style de rendu avec les MIX de scrap " FoolScreen " via le logiciel Universal XML Scraper V2.
                  • A Former User
                    A Former User @MikOzzZ last edited by
                    @mikozzz said in [Theme] Clean Retro:
                    Absolument pas... on ne peut pas utiliser les mix Foolscreen dans d'autres thèmes comme le mien! J'ai fait mes propres mix pour chaque système. J'ai seulement prit le code et la borne d'arcade de Foolscreen pour l'arcade. Cependant j'ai du modifié beaucoup de trucs pour l'adapter.
                    toto421 1 Reply Last reply Reply Quote 0
                      @deletedaccount Tu n'as pas lu la license : Creative Commons Attribution-NonCommercial-NoDerivs 4.0 License CC BY-NC-ND
                      En aucun cas tu ne peux modifier ce qui provient de recalbox-next. Donc c'est :
                      Tu es en CC-BY-NC-SA, nous sommes en CC BY-NC-ND. Tu ne peux pas modifier la license de ce qui provient de recalbox-next.
                      • A Former User
                        A Former User @Substring last edited by A Former User
                        @substring Excuse moi, mais c'est écrit le contraire dans le fichier de license du thème recalbox-next. Recalbox c'est open source et vous utiliser des logos licencié. Légalement j'ai le droit de prendre un thème et de le modifier tant et aussi longtemps que mon thème reste sous la même license et open source.
                        https://gitlab.com/recalbox/recalbox-themes/tree/master/themes/recalbox-next
                          @deletedaccount Encore un qui confond open source, libre, GPL et toute la clique derrière ...
                          Les logos licensiés ? Ce qui veut dire que toi tu as tout droit dessus ? Non non non, faut pas déconner là.
                          Mais va pour CC-BY-NC-SA.
                          • A Former User
                            @substring Désolé je ne suis pas un professionnel des license mais peu importe si on oublie fait que j'ai mentionné les logos je te dirais que c'est tout simplement écrit sur votre gitlab que j'ai le droit. Explique moi ce que j'ai fait et que je n'ai pas le droit de faire exactement. Ton intervention n'est pas claire et je ne comprend pas. Merci.
                              @deletedaccount va pour CC-BY-NC-SA, on s'en tient là.
                              SuperMagicom 1 Reply Last reply Reply Quote 0
                              • SuperMagicom
                                SuperMagicom @Substring last edited by
                                @substring I am confused by the licensing too. Are you saying that the Recalbox-Next theme may not be modified at all or just that if a theme is a modification of Recalbox-Next you must use the same licensing terms and credit the original author(s)?
                                • toto421
                                  @deletedaccount dommage que tu n'ai pas partagé tes mix avec ton thème.
                                  avec d'autres mix le rendu n'ai pas le même.
                                  • Rick Serrano
                                    Rick Serrano last edited by Rick Serrano
                                    **I don't know why but when I select this theme, the start button menu words change into blocks and lines.
                                    Any suggestions??
                                    the start button menu words change into blocks and lines.**
                                      Substring @SuperMagicom last edited by
                                      @supermagicom there is problem between the theme itself and the main readme. In anyway, you have to keep the same license and credit the recalbox team. It's regarding modifications that there is a confusion. Any way, any edit is welcome on gitlab.
                                      • A Former User
                                        A Former User @toto421 last edited by A Former User
                                        @toto421 Salut toto, les mix d'images ne sont pas disponible pour l'instant car il y a un problème de copyright et je dois éditer chaque mix un à un. Donc dès que j'aurai une minute je modifierai le lien et ajouterai les mix pour UXS. Désolé du délais je comprend la déception.
                                        @rick-serrano said in [Theme] Clean Retro:
                                        Any suggestions??
                                        Try changing the language to English. There's a known issue about this and should be fixed in the next RB update.
                                        • makination
                                          makination last edited by
                                          Best theme in my opinion!!! Congratulations
                                          On SNES system, i try the EU version, console on main menu looks ok, but the gamepad on the top of the screen is appearing with the US version. Can you fix it?
                                          Thanks!
                                          • A Former User
                                            A Former User @makination last edited by
                                            @makination said in [Theme] Clean Retro:
                                            Thanks!
                                            Hi makination,
                                            It's a known issue. When importing the svg in Photoshop the buttons of the EU controller dissapear. I didn't found a way. We currently are replacing all controller SVG on this theme and this should fix the issue 🙂
