    Power Script PIN356ONOFFRESET avec switches SNES d'origine
    pin356onoffrese on off button snes originale
    8
    80
    21138
      voljega Banned @FF-Sounds last edited by
      @ff-sounds ouais mais d'expérience des fois la ligne 1444 root grep emulatorlauncher n'est pas renvoyé 😄
      donne moi le résultat de la commande ps -ef | grep emulatorlauncher en jeu ?
      FF-Sounds 1 Reply Last reply Reply Quote 0
      • FF-Sounds
        FF-Sounds @voljega last edited by
        @voljega
        ça donne ça :
        # ps -ef | grep emulatorlauncher
         1437 root     sh -c python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc -p1index 0 -p1guid 05000000504c415953544154494f4e00 -p1name "PLAYSTATION(R)3 Controller" -p1nbaxes 4 -p1devicepath /dev/input/event2 -p2index 1 -p2guid 15000000010000000100000000010000 -p2name "SNES pad" -p2nbaxes 2 -p2devicepath /dev/input/event0 -p3index 2 -p3guid 15000000010000000100000000010000 -p3name "SNES pad" -p3nbaxes 2 -p3devicepath /dev/input/event1  -system gba -rom /recalbox/share/roms/gba/Anguna\ \(Nathan\ Tolbert\ and\ Chris\ Hildenbrand\).gba -emulator default -core default -ratio auto 2> /recalbox/share/system/logs/es_launch_stderr.log | head -300 > /recalbox/share/system/logs/es_launch_stdout.log
         1438 root     python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc -p1index 0 -p1guid 05000000504c415953544154494f4e00 -p1name PLAYSTATION(R)3 Controller -p1nbaxes 4 -p1devicepath /dev/input/event2 -p2index 1 -p2guid 15000000010000000100000000010000 -p2name SNES pad -p2nbaxes 2 -p2devicepath /dev/input/event0 -p3index 2 -p3guid 15000000010000000100000000010000 -p3name SNES pad -p3nbaxes 2 -p3devicepath /dev/input/event1 -system gba -rom /recalbox/share/roms/gba/Anguna (Nathan Tolbert and Chris Hildenbrand).gba -emulator default -core default -ratio auto
         1548 root     grep emulatorlauncher
        Dans ce cas, il faut vérifier aussi si grep est présent dans le résultat
        => si oui, >=2 sinon >=1
          voljega Banned @FF-Sounds last edited by voljega
          @ff-sounds grepper grep ça va être dur 😛
          essaye ps cax | grep emulatorlauncher ?
          sinon fouille là dedans : https://stackoverflow.com/questions/9117507/linux-unix-command-to-determine-if-process-is-running?utm_medium=organic&utm_source=google_rich_qa&utm_campaign=google_rich_qa
          • azvarel
            azvarel last edited by
            @supernature2k after the last update or the 2018.03.30 version, I do not remember for sure, the led is not lit when it enters the recalbox, it just turns on when I turn on the raspberry.
            Zodian Theme | #SNESProject
            • NeeeeB
              NeeeeB last edited by
              @ff-sounds moi je testerais si tmp contient la chaîne de caractères "-p1guid", ce qui n'est pas le cas quand tu es dans ES.
              Vieux geek ^^
              • FF-Sounds
                FF-Sounds @NeeeeB last edited by
                @voljega
                Je vais regarder à ça, merci pour le tuyau
                @neeeeb
                grep retourne p1guid sous ES aussi , il renvoi la commande en fait, donc l'idée de tester si présence d'une suite de caractère semble mauvaise.
                C'est peut être pour ça qu'à la base c'est par les PID que la fonction offreset() est faite.
                Je vais voir pour reprendre cette piste si pas concluant avec grep !
                NeeeeB 1 Reply Last reply Reply Quote 0
                • FF-Sounds
                  @NeeeeB @voljega
                  ps -ef | grep [e]mulatorlauncher corrige le problème, ,merci le lien 😉
                  Petit truc louche qui vient de m'arriver, j'ai descendu le store électrique du salon à l'instant car ça cogne dur, hé ben recalbox a reboot en appuyant sur l'interrupteur (mural je précise) !!!
                  @supernature2k @Substring, une idée du pourquoi ? la gestion du GPIO et de la masse ?
                  Holala, j'ai pas fini avec tout ça... lol
                    @ff-sounds said in Power Script PIN356ONOFFRESET avec switches SNES d'origine:
                    ahah oui c'est un vieux bug, je croyais que le nouveau script corrigeait le problème
                    • FF-Sounds
                      FF-Sounds last edited by FF-Sounds
                      @voljega @NeeeeB
                      YOUHOUU ! ça fonctionne !
                      il y avait 2 problèmes en fait:
                      • celui corrigé par la commande ps -ef | grep [e]mulatorlauncher
                      • Et le Popen qui n'envoyait pas la dite commande...
                        donc on corrige avec proce=subprocess.Popen(['/bin/sh', '-c', 'ps -ef | grep [e]mulatorlauncher'], stdout=subprocess.PIPE)
                      @supernature2k copie @Substring
                      Quand tu me demandais de faire une MR pour l'intégrer, tu parlais d'un script qui gère le onoff et push comme l'actuel ?
                      ou bien seulement le onoff pour uniquement une config matériel ON/OFF + RESET
                      J'entends par là, est ce que tu veux que les appuis courts/longs actuels soient remplacés par ce que j'ai fait ?
                      pour rappel :
                      • switch ON/OFF classique (PUSH serait éventuellement : shutdown propre quelque soit le temps d'appui, en fait je crois qu'il n'y aurait rien à changer dans ce cas, à tester sinon ONOFFRESET et PUSHRESET plus nécéssaire)
                      • Reset court en jeu => reset du jeu
                      • Reset long en jeu => retour ES
                      • Reset court sous ES => reboot propre
                      • Reset long sous ES => rien
                      Dites-moi 😉
                      EDIT: pour info, la gestion LED fonctionne correctement aussi 😉
                        Comprends rien à ce qu'on me demande, j'ai rien fait c'est pas moi !
                        • NeeeeB
                          NeeeeB @FF-Sounds last edited by
                          @ff-sounds bon bah tant mieux si ça marche, par contre je ne comprend pas quand tu dis que ça renvoie p1guid sous ES...
                          Tu as posté ça un peu plus haut quand je t'ai demandé de tester la commande sous ES :
                          login as: root
                          root@192.168.199.17's password:
                          Je dois avoir des problèmes de vision parce que je ne vois pas de p1guid là dedans ^^
                          Vieux geek ^^
                          • FF-Sounds
                            FF-Sounds @Substring last edited by
                            @substring said in Power Script PIN356ONOFFRESET avec switches SNES d'origine:
                            LOL !! t'inquiètes ça va bien se passer 🙂
                            • FF-Sounds
                              @neeeeb
                              grep vérifie aussi ce qu'il a envoyé comme argument, c'est un peu con mais c'est comme ça ^^
                              Regarde :
                              login as: root
                              # ps -ef | grep peaudefesse
                               1380 root     grep peaudefesse
                              # ps -ef | grep [p]eaudefesse
                              Donc il faut passer par [] pour qu'il ne se trouve pas lui même...
                              il cherche tout ce qui fini par eaudefesse avec p devant, ça change tout car il ne trouvera pas [p]eaudefesse 😉
                              Substring NeeeeB 2 Replies Last reply Reply Quote 0
                                Substring @FF-Sounds last edited by
                                @ff-sounds perso je re grep avec | grep -v grep
                                • FF-Sounds
                                  moi je ne grep que depuis moins d'une semaine ^^ mais ça me semble logique au final 🙂
                                  • FF-Sounds
                                    @substring @supernature2k
                                    Substring, normal que tu sois paumé ^^ je t'ai jeté dans le bateau en chemin, mais ne te sens pas obligé de participer 😉
                                    Un rapide résumé :
                                    • Actuellement pour PIN356PUSHRESET on a ceci (PIN356ONOFFRESET, a moitié opérant, car pas de gestion switch):
                                    durée/bouton sous ES En jeu
                                    RESET court rien reset du jeu (RetroArch only)
                                    RESET long reset propre du système reset propre du système
                                    POWER court rien quit du system et retour à ES
                                    POWER long shutdown propre du système reset propre du système
                                    • Le script modifié avec un peu d'aide ^^ fait ceci (valable pour PIN356ONOFFRESET et par défaut PIN356PUSHRESET) :
                                    RESET court reset propre du système reset du jeu (RetroArch only)
                                    RESET long rien quit du system et retour à ES
                                    POWER court/Switch POWER shutdown propre du système shutdown propre du système
                                    POWER long/Switch POWER shutdown propre du système shutdown propre du système
                                    Donc, dans la MR, je demande purement un remplacement de rpi-pin356-power.py ou une option en plus pour recalbox.conf ?
                                    Car finalement PIN356PUSHRESET n'a plus lieu d'être avec ce script modifié...
                                      @ff-sounds dans ta version, power fait toujours pareil
                                      • FF-Sounds
                                        @substring
                                        Oui c'est voulu, le power c'est pour allumer/éteindre, il n'a pas de gestion d'appui, il a une fonction classique, comme la majorité des appareils qu'on connait.
                                        D'ailleurs, il n'a plus besoin de faire plus, car les autres fonctions sont assurées par le reset.
                                        On se retrouve dans une config "normale".
                                        Après je comprends que ça ne puisse pas plaire à tout le monde ^^
                                          @ff-sounds tu as perdu la partie reset pripre de l'os 😕
                                          • FF-Sounds
                                            @substring
                                            Hé bien oui, il est sur le reset court sous ES... Est ce qu'il y a encore un intérêt à avoir un reset propre sur POWER ?
                                            Pour moi non, les joueurs ayant 2 boutons, n'ont pas besoin d'un double reset propre.
                                            A la limite, pour ceux qui ont un seul bouton PUSH pour ON/OFF, il faudrait modifier aussi le rpi-pin56-power.py pour qu'il gère les appuis courts/longs
                                            Je pourrais m'en occupé si nécéssaire 😉
                                            100.8k
