    PSP not in system selection menu
    Your recalbox
    psp selection
    3526
    • Tatahoo
      Tatahoo last edited by
      Hey guys
      First of all, thanks for reading!
      Im having trouble with PSP - ccant make it appear on the menu of recalbox, even tough I placed a ISO file on the PSP roms folder. I opened my ES_SYSTEMS.CONFIG file of emustation and noticed that psp is not there either. Is it a problem with this file? Is there anywhere I can get ES_SYSTEMS.CONFIG with PSP included?
      Thanks for tthe support.
        paradadf Staff @Tatahoo last edited by
        @tatahoo psp is available for boards starting with the RPi3, see following table:
        https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
        • Tatahoo
          @paradadf Hi Man, thanks for the info! But shouldnt I be able to see the emulator in the menu since my board is RPi3, regardless of actual performance in game?
          Thanks for you help!
            paradadf Staff @Tatahoo last edited by paradadf
            @tatahoo yes, you should. But you should also have es_system.cfg right, which you apparently don‘t have. And you should see the psp folder inside the roms folder as well. There must be something weird with your installation or you don‘t have actually a rpi3.
              voljega Banned @paradadf last edited by
              @paradadf or not an official image
                paradadf Staff @voljega last edited by
                @voljega indeed.
                • Tatahoo
                  I tried differente isos already, that shouldnt be the problem... is there any way I can kinda fix my es_systems.cfg without just performing a whole new instalation on my card?
                  Thanks everyone.
                    @tatahoo give us the link to your support archive. Otherwise we can’t help.
                    • Tatahoo
                      Hi @paradadf , how have you been?Hope you're doing great!
                      As requested, here is the link to my support file. Thank you for the help!
                      https://www107.zippyshare.com/v/bmmTSYN9/file.html
                        OyyoDams Staff @Tatahoo last edited by
                        @tatahoo your Recalbox version is NOT official. You've installed a pre-packaged version named Galisteo. Please reinstall Recalbox from the official image: http://archive.recalbox.com/
                        You won't get any support for your version.
                        • Tatahoo
                          @OyyoDams Oh, I guess Ive been fooled then, I bought this from an internet vendor. Thanks for the help man, Ill fix this!
