    Ghost/Phantom Inputs in Emulationstation
    input lag bluetooth
    3801
    • lexx
      lexx last edited by
      Hey there!
      A few weeks ago I switched to RecalBox and I absolutely love it so far.
      I used some time lately to reorganize my library of games.
      Before I had a little smaller library and ghost/phantom input just rarely happened. For example: When I scroll down the game list of a platform, it would just go on until I press another key.
      Now that my library is bigger, it happens much more. Actually so often that I can't use my controller in Emulationstation anymore.
      Here is what I use:
      Raspberry Pi 3b
      Asus BT 4.0 Dongle
      2TB HDD
      Sony Dual Shock 4
      8bitdo NES30 Pro
      Rii i8+ Keyboard
      These input problems do not happen when I use the Rii i8+ Keyboard, which came with his own dongle.
      It does happen with both Controllers. Doesn't make a difference if I use my BT Dongle or the onboard BT.
      What I still need to try is if it happens when I use a cable connected to a controller.
      What's the cause of the problem?
      Since it only happens in the game list, I assume that the huge amount of scraped images are causing it(?)
      Can you reduce it somehow? New/other Bluetooth dongle? Wait for the RecalBox Version for the 3b+?
      Overclock higher than 1300Mhz?
      Anything that could help is appreciated.
      Thanks,
      lexx
      Von privat direkt zu dir.
        Substring @lexx last edited by
        @lexx start evtest and check all input devices to see which one is sending ghost inputs. Have you enabled the gpio controls ?
        lexx 1 Reply Last reply Reply Quote 1
        • lexx
          lexx @Substring last edited by lexx
          @substring Thank you for answering.
          I usually have only the PS4 controller paired. The 8bitdo is never being used. Only tried it out to see if I also have the problem with that one as well.
          Only the Rii i8+ with his own dongle is connected and my PS4 controller over Bluetooth
          I've tried the evtest just now. Here are two pictures.
          Strange is that I see the keyboard twice. And the test itself was too fast to see any manual input from the controller. Edit: You can actually see one from me.
          I did not enable gpio controls. Isn't that related to multiple arcade controllers? I'll look it up.
            @lexx which controller generated all those outputs ? which number in [0-2] ?
            • lexx
              @substring It was 2 - the Wireless Controller aka PS4.
              Edit: Same happens with the 8bitdo NES30.
              The pictures from the post above were with onboard Bluetooth enabled and no dongle connected.
              I now disabled onboard Bluetooth and added my dongle. It works a bit better, but it's still hard to navigate through the Emulationstation menu. Still ghost inputs. Only the keyboard works flawlessly.
              In-game everything is fine.
                @lexx your pad looks like it's not calibrated as it's alays sending inputs
                • lexx
                  @substring Anything I can do about it?
                  Another edit: After thinking about it ...
                  That would be strange as it has no problems in games. At all. It's only happening in Emulationstation. Nowhere else.
                  I'm confused.
                    @lexx the gamepad is constantly moving of 1/256th, so most emulator that use digital inputs wouldn't notice it
