    PocketSNES (snes9x2002) rendering issues?
    Emulator Arcade/PC/Console
    pocketsnes snes9x2002 rendering
    2378
    • dotmick
      dotmick last edited by
      Hi guys,
      I am currently making tests with RetroPie/RecalBox and with one specific game for now (Sailor Moon (U)). I've noticed some differences in the rendering of the game.
      Original game:
      1a 2a
      RecalBox (PocketSNES)
      1b 2b
      Any idea why it's doing that? Is there a way to fix it?
      Thanks!
        Substring @dotmick last edited by
        @dotmick why not use snes9x-next ?
        dotmick 1 Reply Last reply Reply Quote 0
        • dotmick
          dotmick @Substring last edited by
          @substring I didn't know I had other options than PocketSNES. How can I change to snes9x-next?
          • dotmick
            Alright I've managed to change the core and it is now fixed, thanks!
            (slightly slower than PocketSNES but better graphic fidelity)
              @dotmick this can be done system-wide or rom specific. Either press select on the rom and edit metadata, either press start then go to advanced settings. On which pi are you ? Pi3 should have snes9x-next by default
              • dotmick
                @substring Pi0. I've changed it inside recalbox.conf.
                  @dotmick oh yeah, that's a problem, snes9x-next won't run well
                  • dotmick
                    Oh, really? Pi0 not powerful enough?
                      @dotmick indeed. It seems catsfc wasbthe default snes emulator as far as i can remember (maybe it was renamed ?)
                      • dotmick
                        @substring said in PocketSNES (snes9x2002) rendering issues?:
                        catsfc
                        catsfc is snes9x2005 right?
                          @dotmick probably, it may have been renamed some time ago
