    Install recalbox afterwards
    afterwards
    • bernddasbrot
      bernddasbrot last edited by
      Hi, I have already installed Raspbian and openelec via NOOBS on my raspberry PI. Now i heard of this supercool project recalbox and i wanted to ask if anybody knows if there is a possibility to install recalbox afterwards additionally to the other operating systems, or if i have to save all my work and formate my sd-card again. Thanks for your help.
      • digitaLumberjack
        Hi, you will have to reformat your sd card. I should recommend you to get a new one (16gb sandisk ultra is <10$), that way you will keep your OS next to recalbox 🙂
        • bernddasbrot
          Thanks for your reply. Mhh ja i know that sd cards are not very expensive, but i would like to have it all on one card, so that i don't have to swap the cards always. So i have to store all my important files in order to format my sd card. Is there a Noobs-Package that can install the three Operating Systems Raspbian,  openelec AND recalbox?
            Look this wiki to have more informations about a dual/triple-boot setup : https://github.com/digitalLumberjack/recalbox-os/wiki/Setup-a-dual-boot-raspbian-recalboxOS-(EN)
