    Raspberry pi zero w loses usb controller signal
    GamePad/GPIO/USB encoder
    zero loses usb signal
    • Greed
      Greed last edited by Greed
      Hi everyone
      I'm actually facing a small problem on a sideproject.
      Doing a very small gamestation with pi zero w.
      I'm testing it with a microsoft usb controller (that has always perfectly work on my main raspberry pi 3 gamestation).
      The controller works for the first 30 seconds of game and then it's like the pi loses it.
      On emulator like snes i can unplug and plug back but on neo geo it doesn't work.
      I've tried to set the max usb current to 1 thinking it might be a power loss but it doesn't change anything.
      After another test, it seems that it happens only when i use left thumb stick. Like the signal gets blocked (i can hve my character staying crouched, or wlaking straight and nothing stops it).
      Could it have a link with the fact that for stick we only confiure up and left now ?
      Do you have any clue about this problem ? I haven't seen it on the forum
      Best regards
        Substring @Greed last edited by
        @greed it's not an emulation problem. Rather a driver/kernel/hardware problem
        • Greed
          Thank you,
          Any idea how to solve that ?
            @greed not at all, should furst see kernel messages when the problem happens
