    Moonlight not working
    Emulator Arcade/PC/Console
    moonlight
    3957
    • Fuzzel
      Fuzzel last edited by
      Good evening,
      after the latest update Moonlight didn't work for me anymore. So I tried to pair my pc and my recalbox again and it sais:
      Searching for server...
      Connect to 192.168.0.5...
      Generating certificate...done
      Can't connect to server 192.168.0.5
      ERROR mlPair() : could not pair. Exiting ...
      Using the "clean" command and reseting all entries in GFE / Shield didn't work neither.
      Any ideas?
      Above IP Adress is correct (=from my PC)
      Iam using the latest Geforce Driver. 391.35
      • Fuzzel
        Problem solved. GFE installed version 3.13 which isnt supported yet. Downgraded and working fine now again.
        Thank you!
          Substring @Fuzzel last edited by
          @fuzzel have you tried the "find" otion first ? Looks like either gfe hasn't started on your pc, either network problems
          • Fuzzel
            Fuzzel last edited by Fuzzel
            Yes, i found the problem: It was not on account of Recalbox, but GFE. It always updates to Version 3.13. The solutions I have found on the internet (Deletions of Update files, Update Blocking in firewall etc.) don't work. It always updates from 3.12 to 3.13.
            Is there a solution for this "update problem"? Sorry, its no Recalbox problem, just connected to it.
            May I ask this in this forum?
              @fuzzel are you saying it doesn't work with gfe 3.13 ?
              • Fuzzel
                I think so. With GFE 3.12 it works, with GFE 3.13 it does not.
                This also conforms with the changelog of Recalbox 18.03.16: "Moonlight: b*mp to 2.4.6, supports up to GFE 3.12 [...]"
                https://www.recalbox.com/blog/en/post/blog-2018-03-16-recalbox-18.03.16/
                  @fuzzel be cause i had not tested with GFE 3.13, and i saw no mention of changes in the gamestream protocol in GFE 3.13
                  Will_27 1 Reply Last reply Reply Quote 0
                  • Fuzzel
                    Maybe other users have ohter experiences? My recalbox/moonlight doesn't run with GFE 3.13 but with GFE 3.12.
                    • Will_27
                      Will_27 @Substring last edited by
                      @substring I confirm, with GFE 3.13.1.30 it work, I can view my desktop, play games and videos from the web or VLC.
                      I used the commands :
                      cd /recalbox/scripts/moonlight
                      ./Moonlight.sh pair <MY_IP>
                      ./Moonlight.sh init <MY_IP>
                      reboot
                      Sometimes, the application or games won't launch but I can view my desktop and I can launch the application or the game, it's not a problem for me. The sound work fine.
                      I need only to stop the stream with GFE from Shield - GameStream option to get back in the menu of the Recalbox.
