    Solved Bios systems not working need help
    Emulator Arcade/PC/Console
    bios systems need help
    8
    41
    20739
    • Russell Biering
      Russell Biering last edited by
      I'm using recalbox on a dell optiplex 755 with a flash drive. I've put all the games that use roms and no bios but when I add games the need a bios they don't work just go to the black screen then goes back to the menu. I've put my bios file in the bios folder I've made a folder of the system in the bios I've put the bios in the roms folder and nothing works I've try psx fds dreamcast and no geo they want work at all. If any one can help me out I would appreciate it very much I want to play my CD base consoles and other bios systems.
      • ivwshane
        ivwshane last edited by
        The bios files are very particular and its easy to not have the correct ones.
        This page tells you the correct names and case the bios files should be in. It also has the md5 hash so you can see how it compares to your file.
        https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-(EN)
        Russell Biering 1 Reply Last reply Reply Quote 0
        • abunille
          abunille @Russell Biering last edited by
          This post is deleted!
          • Russell Biering
            Russell Biering @ivwshane last edited by
            @ivwshane thanks for helping me out I do appreciate it. But I followed this and got the right bios for psx and it still didn't work could you give me a step by step are send me a link to the bios you got. Are show me how to do it.
            Substring ivwshane 2 Replies Last reply Reply Quote 0
              Substring @Russell Biering last edited by
              @russell-biering don't ask for copyrighted content, thank you.
              • ivwshane
                ivwshane @Russell Biering last edited by
                @russell-biering
                What's the name of the bios file you are using (type it exactly as it appears on your recalbox)? Also paste the md5 hash for the file you have.
                Lets focus on one psx game for right now. What game are you trying to play and what file format is it in?
                Does any game on any system work? What about the games that come preinstalled?
                • Russell Biering
                  @ivwshane I've tried medevil and I put the rom in the rom folder and it shows up in the folder. Then I put the bios the I had it's the sch1001 bios and put it in the bios folder. I loaded it and it shows the game in list but I when I go to play the game it goes black and goes back to the menu.
                  • Russell Biering
                    @russell-biering what is the md5 hash
                    ivwshane 1 Reply Last reply Reply Quote 0
                    • ivwshane
                      @russell-biering
                      The md5 hash (a series of numbers) is posted in that link I posted.
                      Download and install this program:
                      http://www.winmd5.com
                      Run the program and drag the bios file you have onto the top box of the program. It will process the file and then display a hash # and if your bios is the same as the required one then your number should match the # on the page I posted earlier.
                      • Russell Biering
                        @ivwshane I did all of that. What all is going in the bios folder. I put all the right bios for Sega CD in the bios folder I check the md5 hash and the ones I put in there match the ones on the wiki page and it still did work. Psx work because I change to emulators and core but it still says missing bios but it works so what am I doing wrong
                        ivwshane Substring 2 Replies Last reply Reply Quote 0
                        • ivwshane
                          @russell-biering
                          I'm not sure how it can work but still give you a missing bios error, unless the game and bios are from a different region.
                          Maybe you can post your log file.
                          Russell Biering 2 Replies Last reply Reply Quote 0
                          • olivierdroid92
                            As long as your MD5 hash is OK, bios will works.
                            You just need to have the correct typo whicht is requested : as exemple "dc_boot.bin" and not "DC-boot.bin"
                              @russell-biering go to http://recalbox to check your bios
                              • Russell Biering
                                @ivwshane it while trying the psx it say missing bios file in yellow and runs the game perfect
                                • Russell Biering
                                  Russell Biering @Substring last edited by
                                  @substring I've did this and have the correct bios. I did it with the Sega CD. I put every bios the md5 program and everyone the match it I but in my bios folder and it still didn't work and I have both my cue and bin of the game in the roms folder
                                  • Russell Biering
                                    @ivwshane tell me what I have to after I check the md5 and put it in my bios folder.
                                      @russell-biering then drop roms, carefully read the readme.txt in each rom folder
                                      • Russell Biering
                                        @substring I've done this and it still does work. I got psx to work with one game and it has a cue and bin file. But when I do another game with a cue and two bin files that say track one and track two. I've got Sega CD to run but psx just doesn't work right. And don't get me started on the 3do I have the right bios that's on the wiki and md5 hash matches and it want play at all. And I read every read me for these two and they say you need iso. .cue . Bin and tried all
                                          @russell-biering recalbox is case sensitive. If the cue files reference some unexistng bib files, it can't work. Make sure files are properly named (case sensitive ...)
                                          • Russell Biering
                                            @substring can you give me sample of what it should look like
                                            voljega Russell Biering 2 Replies Last reply Reply Quote 0
