    Amiga game don´t launch
    Emulator Arcade/PC/Console
    amiga don´t launch
    3763
    • warhead999
      warhead999 last edited by
      I have problems to launch amiga games, if i click on the game a black screen is coming and after a few seconds the start screen coming back.
      i check the correct bios version in the bios folder and they ok
      i tried this with a lot of games in ADF Format with amiga 600 and 1200 without success ... have you an idea?
      The system is new installed on rasbberry Pi3
        voljega Banned @warhead999 last edited by
        @warhead999 most likely your bios files are wrongly named (it shall be all lower cases) and you need at least kikstart13 and kickstart31.
        If it still does not work, do a support archive after having tried to launch a game
        • warhead999
          I have following kick start in the folder with this names :
          kick13.rom 82a21c1890cae844b3df741f2762d48d
          kick20.rom dc10d7bdd1b6f450773dfb558477c230
          kick31.rom 646773759326fbac3b2311fd8c8793ee
          it seems to be ok or?
            @warhead999 I asume you meant the folder /recalbox/share/bios (and not /recalbox/share/bios/amiga)
            yes this is correct.
            so try to launch a game and make a support archive : http://recalbox/help with your recalbox on (via Chrome if needed)
            warhead999 1 Reply Last reply Reply Quote 0
            • warhead999
              warhead999 @voljega last edited by
              @voljega yes i mean \recalbox\share\bios
              here the support file link https://file.ac/BQmPGwf3CG4/
                @warhead999 clearly your kickstarts are not found, either they are not well named or not in the right place :
                  File "/usr/lib/python2.7/site-packages/configgen/generators/amiberry/adfGenerator.py", line 16, in generateAdf
                    raise IOError("No %s kickstarts found" %amigaHardware)
                IOError: No amiga1200 kickstarts found
                Also Barbarian is one the few games running much too quickly on amiga1200, better to launch it on amiga600
                • warhead999
                  Ok thx it was my fault i thought i don´t need to upload the kickstart roms 🙂 Now after searching the right files i can launch arkanois for example 🙂
