    Will the next update include?.....
    Themes & Interface
    next update include
    • BlockABoots
      BlockABoots last edited by BlockABoots
      This latest update to Recalbox is a massive improvement and has a lot of nice new feature but there are still some features missing.
      Will the next via the UI allow you to update....
      Update Retroarch
      Allow you to add your own cores for RetroArch
      Update the cores for RetroArch
      Update Overlays and Shaders for Retroarch
      Be able to download ES themes
      These are currently features that Retropie allows you to do and i think its the only thing stopping Retropie being better than Recalbox. If recal box allowed you to configure Retroarch more (like retropie does) then it would be the go to image to use for RPi devices!
      thanks
      • Dragu
        Dragu Banned last edited by
        @blockaboots said in Will the next update include?.....:
        This is also now already possible.
        • BlockABoots
          @dragu said in Will the next update include?.....:
          Its only a select few though not many
            https://gitlab.com/recalbox/recalbox/blob/master/CHANGELOG.md
            Update Retroarch
            soon
            never buildroot OS.
            Only if necessary
            it's up to you
            you can download any shaders or overlays by yourself
            may be one day. But not now , it's a huge work.
