    Moonlight problem, moonlight.conf doesn't exist
    Emulator Arcade/PC/Console
    moonlight
    • jor2404
      jor2404 last edited by
      I have updated to the lastest recalbox version. After that I have paired moonlight with my pc, the when I try to run init command I get /recalbox/share/system/configs/moonlight/moonlight.conf or doesn't exist. Have you added the right arguments to the script ?
      moonlight.conf doesn´t exist. What can I do?
        Substring @jor2404 last edited by
        @jor2404 try :
        mv ~/configs/moonlight ~/configs/moonlight.old
        reboot
        Then pair + init again as, at reboot, the moonlight folder should be restored to default
        • jor2404
          @Substring I did that and now whe I run pair command I get this:
          /recalbox/scripts/moonlight/Moonlight.sh pair
          () /recalbox/share/system/configs/moonlight/moonlight.conf | /recalbox/share/system/configs/moonlight/keydir
          Searching for server...
          Connect to 192.168.1.104...
          Generating certificate...done
          Please enter the following PIN on the target PC: 7157
          *** Error in `moonlight': malloc(): memory corruption: 0x00f6bcf8 ***
          /recalbox/scripts/moonlight/Moonlight.sh: line 33: 1299 Aborted moonlight pair -keydir $mlKeydir $mlIp
          ERROR mlPair() : could not pair. Exiting ..
          Substring 1 Reply Last reply Reply Quote 1
            @jor2404 said in Moonlight problem, moonlight.conf doesn't exist:
            WTF ??? never such an error, can't be of much help with this
