    Solved FTP'ing files, how to remove read-only permissions?
    ftping remove read-only permissions
    • BlockABoots
      BlockABoots last edited by
      Im trying to use FileZilla to transfer some shaders over to the shader folder, 'shader directory /recalbox/share_init/shaders' but when i try and copy the files i get an error message ....
      /recalbox/share_init/shaders/zfast_crt_standard.glslp: open for write: received failure with description 'Read-only file system Error: File transfer failed
      how to i remove the read-only file permission?
        Hello
        https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
        mount -o remount,rw /
        BlockABoots 1 Reply Last reply Reply Quote 0
        • BlockABoots
          BlockABoots @acris last edited by
          @acris said in FTP'ing files, how to remove read-only permissions?:
          Hello
          Thank you, that worked
