    Thank you
    thank
    2737
    • damianiw
      damianiw last edited by
      just wanted to say thank you, recalbox up and running on my rpi B (original) and really impressed with speed you got out of it compared to a couple of other distros this is just much quicker and easier. Using original xbox pad with usb, need to get a bluetooth adapter for my ps3 pads to work, would be really good if wii-mote's were supported. Just reading up now but how easy is it to reconfigure the pad for street fighter 2 as hard buttons are mapping to the black & white buttons
      • digitaLumberjack
        Hi, nice to see you enjoy the recalbox os 🙂 Wii mote are not supported for now. I don't understand
        could you be more explicit ?
        • damianiw
          how do I reconfigure the buttons for FBA ? I am using a classic xbox controller via usb and have mapped on the system menu but for street fighter 2 on FBA it assigns the hard kick and hard punch to the black and white buttons.
          • digitaLumberjack
            While configuring just set your triggers as L1 and R1 and the black and white buttons as l2 r2 no ?
            • damianiw
              thanks I will try that, I also just found some tips in the mini faq https://github.com/digitalLumberjack/recalbox-os/wiki/Remapping-controller-FBA
              • damianiw
                I am very impressed with the support you and the community provide please can I ask another question which I have not seen answered anywhere yet, I have an original rpi model b, when I try any name rom it doesn't work I am returned to the menu, I will check my roms later with clrmamepro but is there anything else I should
                • damianiw
                  try
                  • digitaLumberjack
                    https://github.com/digitalLumberjack/recalbox-os/wiki/Add-system-bios-(EN) https://github.com/digitalLumberjack/recalbox-os/wiki/Add-arcade-games-(EN) and https://github.com/digitalLumberjack/recalbox-os/wiki/Check-your-roms-version-with-clrmamepro-(EN) You will see that you will need bios for arcade systems (that is a rom actually) and that you will have to find good versions 🙂 Now that it's said, come on irc channel maybe we can help you 🙂
                    • damianiw
                      hi I've checked and updated my mame and fba sets and got a full bios set, still cannot get mame to load anything is this because I'm on rpi b (256mb) some fba seems to run ok with a few exceptions
