    Solved Raspberry Pi Zero-W, wifi is still on even after being set as off.
    zero-w wifi still being off
    2824
    • dh04000
      dh04000 last edited by
      As the title says, even if I turn the wifi off int he emulation station menu, it is stll on as I see it on my network and I still can access the web-gui. A minor issue, but my raspberry pi zero-w handheld is chewing through power and the battery doesn't last very long.
      Also, how do I toggle off the bluetooth?
      Wanted to give ya'll a heads up since I didn't see anyone else post about it. @Substring
        Substring @dh04000 last edited by
        @dh04000 the best is to use overlays in the config.txt to disable BT
        Regarding the Wifi, i'm surprised, does it get an IP ?
        dh04000 1 Reply Last reply Reply Quote 0
        • dh04000
          dh04000 @Substring last edited by
          @substring Not in the emulationstation menu, but on the network.
            @dh04000 i beg your pardon ???
            • dh04000
              @substring said in Raspberry Pi Zero-W, wifi is still on even after being set as off.:
              I can't get the bug to occur again. It had something to do with using a raspberry pi zero-w and a usb wifi dongle at the same time. (I use the dongle because the zero-w's wifi is so garbage).
              Ignore this post.
                @dh04000 too late, we've been investigating and there is indeed a bug 🙂
                • dh04000
                  @Substring
                  Well, glad to have been a help. lol. 🙂
