    Solved c64 - mouse gui vice
    Emulator Arcade/PC/Console
    c64 mouse gui vice
    • giubbe de Giubbix
      giubbe de Giubbix last edited by
      In the vice push select and push the Up/Right (up/down) D-pad button, but the mouse does not show.
      I use the joypad ps3
      With the emulator amstrad the mouse is shown following the procedure described above.
      What can I do?
      • abunille
        abunille @giubbe de Giubbix last edited by abunille
        @giubbe-de-giubbix
        • Start a Game
        • press y to enter the virtual keyboard
        • press select to switch to mouse
        • play around with up and left analog pad (in my case after a few seconds the mouse is showing)
        • try to use the virtual keyboard
        • giubbe de Giubbix
          Yes, it works
          thank you
          • abunille
            @giubbe-de-giubbix
            you are welcome
