    180316 SEGA CD/MEGA CD Issues games cue, iso wav
    180316 sega cdmega cue iso
    • kelv
      kelv last edited by
      Hello
      I have some games that were cue file indexing the iso and wav files that use to work in previous versions of recalbox they were running ok but in the new one they are not working anymore.
      When I launch the cue file for Sonic CD or for Snatcher both of them are loaded and the bios screen appears however after sega logo, the games are halted in the introduction screen and a strange sound is heard. (retroarch menu works perfectly and I can exit the game with hotkey button) The games in cue and bin format are working fine.
      The recalbox support file are here https://file.ac/yyyFXlu6zqQ/ However it seems that the problem is inside the emulator.
      thx for your help
      Raspberry Pi model: RPi 3b+
      Recalbox build : 7.0.1 DragonBlaze
      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
      Overclocked: 1485 MHZ
      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
        Substring @kelv last edited by
        @kelv we've just added chd extension support, nothing more
        kelv 1 Reply Last reply Reply Quote 0
        • kelv
          kelv @Substring last edited by
          @substring I know, but it's strange. Never mind as I have only two games affected as I only have two games in that format. I'll go for cue-bin approach or chd files.
          thx
          101.4k
