    Theme SPACE ODDITY RECALBOX (18.03.16)
    Themes & Interface
    theme space oddity recalbox 18.03.16
    7859
    • MikOzzZ
      MikOzzZ last edited by
      Salut à tous ,
      Je vous partage le superbe thème SPACE ODDITY que je viens d'adapter pour RECALBOX (18.03.16) de Philippe BELLO :
      https://www.youtube.com/channel/UC6Dx3037ATZK6tAHAy_S9-A
      Ce thème colle parfaitement à RECALBOX maintenant.
      7_1521471333566_snes1.jpg 6_1521471333566_snes 2.jpg 5_1521471333566_pc2.jpg 4_1521471333566_pc1.jpg 3_1521471333566_mas2.jpg 2_1521471333566_mas1.jpg 1_1521471333566_gba2.jpg 0_1521471333566_gba1.jpg
      Disponible ici :
      https://drive.google.com/file/d/15iMa_0MvUp8sF6idC9OFFbiPEivAqIoU/view
      supernature2k 1 Reply Last reply Reply Quote 1
      • supernature2k
        supernature2k @MikOzzZ last edited by
        @mikozzz it looks very nice but you can go further!
        • ya can get rid of all theme.xml in each system folder by using $system variable in the main theme.xml
        • ya could add a menu theme that would stick with the style of the theme
        MikOzzZ 1 Reply Last reply Reply Quote 0
        • MikOzzZ
          MikOzzZ @supernature2k last edited by
          @supernature2k yes actually I can do that as soon as I have a little more time, I had already adapted for the old version of RECALBOX, I just add the missing macines plus vertical carousel.
          Otherwise it's planned I'm still looking at how easily incorporated the new menu to the old theme.
          • DAM
            DAM last edited by
            Hi everybody ! When i select one game, for exemple, was an effect zoom in the scrape image, how i disable this ?
            Thanks
            • MikOzzZ
              Merci d'éditer le post @supernature2k @Substring @s'il vous plait avec ce nouveau lien et les ajouts des nouveaux menus
              https://drive.google.com/open?id=1kylPeFKQXhFFBFAZdzehN99J-p8Yi2Tx
              2_1521479315500_sapce1.jpg 1_1521479315500_sapce3.jpg 0_1521479315500_sapce2.jpg
              • MikOzzZ
                C'est mieux avec l'amiga600/1200 et X68000 🙂
                https://drive.google.com/open?id=1Gql7oYgF3mYXxZh8efs_hjk9TjG7a9xA
                  Substring @MikOzzZ last edited by
                  @mikozzz un effort sur les menus au lieu de copier/coller celui de recalbox-next 😉
                  • MikOzzZ
                    MikOzzZ @Substring last edited by
                    @substring Alors c'est pas un copier coller du menu NEXT mais celui du FUSION 🙂
                    Substring supernature2k 2 Replies Last reply Reply Quote 0
                      @mikozzz la remarque reste valable 😉 un peu d'audace et de créativité, que diable !
                      • supernature2k
                        @mikozzz Non ce sont bien les menus du recalbox-next comme le montre tes screenshots.
                        Tu as fait un simple copier/coller du dossier data du coup tu as des subsets qui ne sont évidemment pas compatible. D'ailleurs il n'y a plus de wheel dans le thème de ce fait.
                        Reprendre des éléments d'autres thèmes ça ne pose pas de problèmes (en indiquant les sources comme je l'ai fait dans Fuzion) mais en revanche il faut les intégrer correctement sinon ça n'a aucun intérêt.
                        • MikOzzZ
                          Évidemment c'était juste de l'adaptation rapide pour que les personnes qui utilisent le nouvelle MAJ et souhaites avoir les nouveaux menus puissent profiter des thèmes rapidement. il est vrai que ce n'est pas moi qui suis fait ses nouveaux menus qui sont superbes je trouve et ne pouvant re-éditer les posts. Et oui @supernature2k je voulais juste avoir le nouveau visuel du menu et la possibilité de changer les boutons manettes sans que ce soit 100 % compatibles a ce que vous avez fait.Et ferais mieux pour les prochaines fois 🙂
                          • ViRuS-MaN
                            ViRuS-MaN last edited by
                            le theme fuzion on peux le mettre sur recalbox ??? si oui on peux le trouver ou
                            • MikOzzZ
                              Je viens de Nettoyer un peu le thème , rajouter une nouvelle vue 8 " CLASSIC WHEEL " pour conserver la vue de la roue d'origine , rajouter les crédits de la team RECALBOX pour les menus etc.....
                              Disponible ici :
                              https://drive.google.com/open?id=1yJeOY8_UteX94ZNXuZoVYD0dQsLtQRlA
                              • ViRuS-MaN
                                la roue tu ne peux pas le mettre sur ton theme comicbook ???
                                100.8k
