    Wont Boot on RPIE2?
    wont boot rpie2
      Guest last edited by
      Hi, I have unzipped recalboxOS-v3.2.11.zip on my pc directly to my micro 64gb SD Card. I plugged it in my rasp pie 2 b+. And All I get is a black screen? ANy idea whats wrong? I have tried it ona HD TV 1080P and a Monitor 1080P both have same problem. The rpie2 seems to have both red and green lights on the whole time, unless I unplug the power cable
        I tried a 16gb micro instead of 64gb micro and it worked, the SD Tool Formatter I use will only format 64gb into exFat and 16gb into FAT32. Now the 16gbis booting and I am able to install.
