    Solved 18.03.16 screen resolution problem.
    18.03.16 problem
    7
    22
    8339
    • alpermis
      alpermis last edited by
      After updating, when I quit a low resolution game, ES resolution stays the same. And most of the screen/menu parts are out of visible area.
      Here are the things I tried so far;
      1. Reinstall
      2. Change video mode to auto
      3. Try to hold my self to throw my newly maid bartop arcade cabin from the window
      None seems to work. And dear developers , I appreciate your work and words cant be enough to explain my appreciation. But it is very very and some more very important to keep old velease files. Atlease 1 version prior.
      Regards,
      https://file.ac/Zy6wqr-agSo/
      OyyoDams Substring 2 Replies Last reply Reply Quote 0
        OyyoDams Staff @alpermis last edited by
        @alpermis thanks four your feedback and your support archive. I'm sure @Substring will take a look as soon as possible.
          Substring @alpermis last edited by Substring
          @alpermis beside what I've told you, you have a common thing with the other guy having the very same problem : your monitor just has DMT modes. That's a good lead
          The log shows
          [       44.50] configgen/videoMode.py(isSupported:68): The resolution for 'CEA 4 HDMI' is not supported by your monitor
          [       44.53] configgen/videoMode.py(autoMode:115): auto mode -> CEA 4 HDMI not supported, fallback to default
          @barto28 has the very same problem, but switching to auto mostly resolved the problem but for N64.
          tekkenism 1 Reply Last reply Reply Quote 0
          • alpermis
            @substring Exactly true. All but N64.
              @alpermis Can you stay on auto mode, launch a N64 game, quit, and make a new support archive please ?
                @alpermis hoh and remove system.es.videomode=auto it's buggy, but will be fixed
                • alpermis
                  I changed system.es.videomode=auto -> system.es.videomode=CEA 4 HDMI (as you asked)
                  Started a N64 game then I quit the game. Screen resolution turned bad. And here is the archive ;
                  https://file.ac/d8MQldK1ta8/
                  • alpermis
                    Another thing might help; I use hdmi to dvi cable. So monitor is in dvi mode.
                      @alpermis ok, try this fix by running SSH commands:
                      mount -o remount, rw /
                      rm /usr/lib/python2.7/site-packages/configgen/utils/videoMode.pyc
                      wget -O /usr/lib/python2.7/site-packages/configgen/utils/videoMode.py https://gitlab.com/recalbox/recalbox-configgen/raw/0769d875ca343ddffd19721e96595e92511470f2/configgen/utils/videoMode.py
                      No need to reboot, just start games from ES including N64
                      tell me if it fixed your problem
                      • Snoopy.kolin
                        Snoopy.kolin last edited by
                        This post is deleted!
                        • alpermis
                          The same.
                          --2018-03-18 14:08:29-- https://gitlab.com/recalbox/recalbox-configgen/raw/0769d875ca343ddffd19721e96595e92511470f2/configgen/utils/videoMode.py
                          Resolving gitlab.com (gitlab.com)... 52.167.219.168
                          Connecting to gitlab.com (gitlab.com)|52.167.219.168|:443... connected.
                          HTTP request sent, awaiting response... 200 OK
                          Length: 4489 (4.4K) [text/plain]
                          Saving to: '/usr/lib/python2.7/site-packages/configgen/utils/videoMode.py'
                          /usr/lib/python2.7/site-packag 100%[====================================================>] 4.38K --.-KB/s in 0s
                          2018-03-18 14:08:30 (12.8 MB/s) - '/usr/lib/python2.7/site-packages/configgen/utils/videoMode.py' saved [4489/4489]
                          Archive when screen was bad;
                          https://file.ac/2CUs1SYzhsY/
                            @alpermis ok, investigating
                              @alpermis new fix :
                              wget -O /usr/lib/python2.7/site-packages/configgen/utils/videoMode.py https://gitlab.com/recalbox/recalbox-configgen/raw/0bc27e90248812a62f80de94810434acbf7ac418/configgen/utils/videoMode.py
                              the rm could fail, not a problem
                              • alpermis
                                It seems fixed 🙂 Thank you very much.
                                I noticed couple of other issues. Im gonna try to be sure about those and open other threds.
                                  @alpermis great thank you for participating in the debugging 🙂
                                  • ViRuS-MaN
                                    ViRuS-MaN last edited by
                                    nickel chrome plus de probleme avec la n64 , merci
                                    • rizzie
                                      rizzie last edited by
                                      Wow thank you. This issue has been resolved. It originated in dreamcast and n64.
                                        Substring @rizzie last edited by
                                        @rizzie happened with systems having a forced resolution
                                        • tekkenism
                                          tekkenism @Substring last edited by
                                          @substring said in 18.03.16 screen resolution problem.:
                                          The log shows
                                          I just wonder where's the path of that log file please? I'd like to see what's going on, on my Recalbox. Thanks.
                                            Substring @tekkenism last edited by
                                            @tekkenism ~/logs/recalbox.log, you can also see it from the webmanager
                                            tekkenism 1 Reply Last reply Reply Quote 1
