    Recalbox 18.03.16 is out!
    Announcements
    recalbox 18.03.16 out
    23
    59
    41568
    • megabug73
      megabug73 last edited by
      hi
      i found an issue, nes games runs too fast, i tried using all emulator included but all runs too fast
      • Grey Fox
        Grey Fox last edited by Grey Fox
        Updated then all it would do is boot to black. Gonna try a fresh install to see if it works properly or just go back to the previous version and throw the updates on a test stick to make sure they do fine next time.
          Substring @megabug73 last edited by
          @megabug73 just tried all 4 cores, no problems
            Substring @Grey Fox last edited by
            @grey-fox how black ? no splash vid ?
            • shaizen
              shaizen @kos last edited by shaizen
              @kos привет,ты нашел решение проблемы?
              hello, you found a solution to the problem?
              Substring kos 2 Replies Last reply Reply Quote 0
                Substring @shaizen last edited by
                @shaizen govori po angliskii pozhaluysta
                shaizen 1 Reply Last reply Reply Quote 1
                • shaizen
                  shaizen @Substring last edited by
                  @substring sorry,ok
                  • kos
                    kos @shaizen last edited by
                    @shaizen нет
                      @shaizen which problem ?
                      shaizen 1 Reply Last reply Reply Quote 0
                      • shaizen
                        @substring the new version does not correctly display the Russian language in the menu.
                        Substring 1 Reply Last reply Reply Quote 1
                          @shaizen translations haven't been merged sadly
                          • Phil
                            Phil last edited by
                            Super boulot! Le rendu est très sympa 🙂
                            • Gimpi
                              Gimpi last edited by
                              realy nice changes cant wait to upgrade ❤
                                voljega Banned last edited by
                                after launching 20-30 games I can confirm that EmulationStation doesn't reappear when exiting a game approximatively 10% of the time ....
                                • kos
                                  kos last edited by
                                  Letters are displayed incorrectly when you select The Russian language.
                                    Substring @kos last edited by
                                    @kos thank you forbthe feedback. Has it ever worked before ?
                                    kos 1 Reply Last reply Reply Quote 0
                                    • kos
                                      kos @Substring last edited by
                                      @substring In the previous two versions everything worked perfectly.
                                        @kos ok thank you for the feedback. You just need to select russian as language ?
                                        • kos
                                          @substring Yes
                                          • raffols
                                            raffols last edited by
                                            Hello, first of all thanks for your contributions. Secondly, I've seen that the new PSP emulator lacks of the multithread option (it was dismissed apparently in 1.5 version) and it is a problem as some games worked really good with that option enabled and now the option does not exist any more and those games do not run well.
                                            I have tried to download previous version of Recalbox from the gitlab.com / tag link but as commented by another user, once you select a previous version and the build to be downloaded I receive a 404 error. Could you please fix it so we can download previous version of Recalbox?
                                            Thanks in advance.
                                            100.3k
