    Recalbox bluetooth dongle
    Your recalbox
    recalbox bluetooth dongle
    • pguerrero
      pguerrero last edited by
      I ve search online and havent found a solution for recalbox.
      All my bluetooth controllers have latency when using the internal bluetooth on recalbox raspberry pi 3
      I ve read online. That using a bluetooth dongle fixes this.
      So i went ahead and bought a dongle which is compatible.
      Ive got 2 sf30 pro controllers from 8bit i wanna use. And i dont know how to set them up using the bluetooth 4.0 dongle that i bought. Nwither if there is a way to turn off the internal bluetooth.
      I tried them using the internal bluetooth but there was still latency on button presses. Which kills any platformer.
      Any solutions on how to set up the bluetooth dongle? Its a generic crs 4.0 bluetooth
      Thanks for the help
        Substring @pguerrero last edited by
        @pguerrero few pro tips:
        • disable onboard wifi (which is done by editing the config.txt), this improves rather well bt performance
        • eventually disable onboard bt (same way)
        USB BT dongles are prioitary over internal BT as they are set up much earlier.
        Now what you must do:
        • reset ypur pads (if you need help, check the 8bitdo or our wiki)
        • forget bt devices inside recalbox
        • reboot
        • pair again
        pguerrero 1 Reply Last reply Reply Quote 0
        • pguerrero
          pguerrero @Substring last edited by
          @substring i am unable to find the config.txt using the command line.
          I f4 out of recalbox
          Alt f2 into command line
          Put in credentials
          Then when i try to do the whole mount i start getting confused
            @pguerrero you need to mount -o remount, rw /boot then edit /boot/config.txt
