    Problem with Dip Switches (mame078 emulator).
    Emulator Arcade/PC/Console
    dip switches mame078 emulator
    • Ozone3
      Ozone3 last edited by
      Hi friends!
      I have a problem with mame078. Meanwhile I was playing Ghosts n' Goblins I entered at Dip Switches menu to change the number of lifes. Sadly, when I went back to the game it froze. I have reverted these changes in Dip Switches menu but it doesn't have taken effect. I suspect that the problem perharps is located in some mame config file (or somthing) where is recorded that configuration. If I'm right, the solution would be problably to delete that file. Does someone know where is this file? If I'm wrong, how can I revert the changes I've done in Dip Switches?
      Thank you in advance.
      Regards.
      100.7k
