    Saving Issues after lastest updates.
    saving lastest updates
    3353
    • boxcarpilot
      boxcarpilot last edited by boxcarpilot
      So Only have SNES roms,
      After updating to 18.02.09, I have been seen issues where the recalbox fails to:
      -Remember new games added to favorites list
      -Fails to remember save files.
      I noticed today, I went to Chrono Trigger... and puff, lost four hours because the save file was deleted? I guess...
      Then I loaded DKC 2, and same, no saved files...
      It has to be something serious, because ES says a game was last played months ago, or never, and that is not true...
      I'm storing roms and scraped info on an external USB drive.
      I did it by following this guide when I was in 4.0
      https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN)
      At this point I would like to:
      1- See if there is any way to recover the saved files
      2- I'm thinking about blowing everything and start from scratch with a more recent BETA version?
      pc1919 Substring 2 Replies Last reply Reply Quote 0
      • pc1919
        pc1919 @boxcarpilot last edited by
        Hi @boxcarpilot,
        I'm new to recalbox and raspberry world, but immediatly seems to have problems.
        I just installed recalbox using NOOBS and after a couple of tries I've came up with your same problem.
        My saved files are overwritten at reboot. This happens to roms, configurations (language, date/time, controllers).
        And this happens if the changes are made through the ui of recalbox, via ssh or via webpage on the local lan.
        By the way, I've a couple of other things:
        1. the partition at the end of the installation has not been enlarged, so it is too small to host roms - is there a way to take all the space available?
        2. haven't managed to use these instructions https://github.com/recalbox/recalbox-os/wiki/Load-your-roms-from-a-network-shared-folder-(EN) to load from a NAS my roms, I guess because at reboot everything is gone. I'll double check this.
        Then i found your post. I will stop trying to understand and will wait for updates.
        A last question. How do I know my exacly installed version of recalbox? Nothing emerges from the web page...
        boxcarpilot 1 Reply Last reply Reply Quote 0
        • pc1919
          pc1919 last edited by
          I've found my version: 18.2.09... is it possible?!
          • boxcarpilot
            boxcarpilot @pc1919 last edited by
            @pc1919 open a new post since you have different issues
            Make sure you followed
            https://www.recalbox.com/diyrecalbox
            16GB SD and using Etcher NOT noobs
            pc1919 1 Reply Last reply Reply Quote 0
              Substring @boxcarpilot last edited by
              @boxcarpilot check the saves folder to see what's been saved and when
              • boxcarpilot
                I checked the saves folder under /share.
                They were there, I exported them and then proceed to test with a PC emulator for snes.
                Unfortunately, it seems they were not saved....
                Anyway, I was thinking about, maybe shutting down the Pi3 via cutting off AC power might not be a good idea.
                I will buy a new case for it, and see if I can program the soft shutdown to a physical button.
                • pc1919
                  @boxcarpilot now it is working. I've done a fresh installation after downloading the full image.
                  I guess the problem is noobs.
                  Thanks.
