    8Bitdo NES30 Pro working with Bluetooth?
    GamePad/GPIO/USB encoder
    8bitdo nes30 bl
    • Everett999
      Everett999 last edited by
      Hi, Before I invest in these controllers, can I use two of them with the built in bluetooth of a RP3? I see these do not have dongles for them. Or do I have to settle for the NES30 with no analog but dongles? Do they set up just like USB controllers minus the pairing?
        Substring @Everett999 last edited by
        @everett999 they set up like any bt device
        • Everett999
          Ok, using a RP3 with the latest Recalbox fisoftware, can i use the 8Bitdo NES30 pro controller with the Pi's built in bluetooth? How many BT controllers can be attached?
          If so, what version of Recalbox this this start being implemented?
          Thanks
            @everett999 said in 8Bitdo NES30 Pro working with Bluetooth?:
            You can. Please read the wiki regarding those pads to know how to start them. Firmware 4.1 is recommended.
            The internal BT is somehow crappy though
            no idea
            Thanks
            The internal bluetooth works since 4.1, that's since october
            • Everett999
              Thank you for the quick reply
