    Dreamcast has constant popping sound or ROMs will not load
    Emulator Arcade/PC/Console
    dreamcast constant popping sound roms
    • zookle
      zookle last edited by
      Hey all, i need help with a Dreamcast issue. First of all im running 4.1 and i do have BIOS in there. Everytime i go to load a game there is popping sound (kind of like when your headphone jack is not in all the way and you get a speaker pop sound).
      For some games only half of the image will display then kick me back to the main menu or i will set the time and date then the screen will sit at gray and i will have to power cycle. I tried different BIOS's but the problem persists.
      I transfered ROMs using WinSCP, and they are all in .chd. Any advice?
        Substring @zookle last edited by
        @zookle we can't do anything regarding what you explained, we don't code the emulators themselves
        Sound popping happens when the alsa buffer underrruns
        For the rest, i can't tell
        zookle 1 Reply Last reply Reply Quote 1
        • zookle
          zookle @Substring last edited by
          @substring No worries man. I didnt know what it was from so you answered my question. I think the other issues are a mix of ROM and BIOS and i can troubleshoot that. Thanks!
