    Fixing teminal emulation reslution (and quit from it)
    fixing teminal reslution quit
    3041
    • niculinux
      niculinux last edited by
      Hello there! Hey when i exit emulationstation by pressing F$ and goin into terminal emulator with ALT + F12 the screen displays offsett and therefore unusable; nay hint on fixing the resolution?
      And please, how i get back to emulation station if possible? So far i reboot the system; there is no other way? Thanks in advance anyways 🙂
      Substring voljega 2 Replies Last reply Reply Quote 0
        Substring @niculinux last edited by
        @niculinux hi
        Which board are you using ?
        • niculinux
          niculinux last edited by niculinux
          Sorry before i meant F4! I have recalbox 19.02.09. plugged via HDMI to an Samsung tv.
          Edit @substring a Raspbery Pi3 model B, sorry again!
            voljega Banned @niculinux last edited by
            @niculinux juste type /etc/init.d/S31emulationstation start
              @niculinux most of times tvs dont properly center the image. Otherwise add some overscan
              • niculinux
                @Substring thnaks, gonna try at home ASAP! To add overscan, it is enough to do in emulationstation or i (fear) to do some tampering with configuration station? As for exiting the terminal, may I emulationstation start or the full path is needed to be provided?
                Edit: please if someone may provide some screenshots it would be more easier 🙂
                  @niculinux start with the es option 😉
                  niculinux 1 Reply Last reply Reply Quote 0
                  • niculinux
                    niculinux @Substring last edited by
                    @substring said in Fixing teminal emulation res**tion (and quit from it):
                    @Substring sorry I could I do that? Maybe youre referring to 4:3, 16:9 options and so on or something else?
                      @niculinux no, afair there's ann ption to enable overscan in ES, nothing to do with the ratio
                      • niculinux
                        Ah ok it is in the "advanced settings" menu ☺ It worked for games (especially sega mster system ones, because of the intermediate resolution these had) but terminal still no way 😞
                        Edit: another solution may be to change manually overscan as the wiki reads:
                        https://github.com/recalbox/recalbox-os/wiki/Overscan-settings-(EN)
                        and see what happens...but since in terminal recalbox provide only vi and vim (i always used nano) and most of all i'm a complete nood i dout gonna try since don't wanna mess with the system ;( well other ideas are more than welcome!
                        May custom overscan be in the future set in emulation station? Would be great, thanks anyways!!
