    Amiga4Ever ROM
    Emulatoren Arcade/PC/Konsole
    amiga4ever rom
    2125
    • Morikali
      Morikali last edited by
      Hallo,
      ich möchte meine alten Amiga Spiele legal wieder spielen. Hierzu habe ich mit Amiga4Ever gekauft um auch legal wieder Kickstarts zu besitzen. Leider stimmt der MD5 Wert der verschiedenen Roms überhaupt nicht mit den Vorgaben unter https://github.com/Voljega/amiga4recalbox überein.
      Mache ich irgendetwas falsch ?
        voljega Banned @Morikali last edited by
        @morikali first of all official integration is on recalbox, no more on my own github : https://github.com/recalbox/recalbox-os/wiki/Amiga-on-Recalbox-(EN)
        This documentation's MD5 should correspond to amigaforever bioses from 2016 or 2017.
        But did you try your bios ? they may still work, just rename them as mentioned in the documentation and it may be ok
        • Morikali
          Hello voljega,
          the problem is that recalbox marks it as "invalid". Even when the name is correct. I uploaded it via webinterface -> BIOS.
          BR morikali
          paradadf voljega 2 Replies Last reply Reply Quote 0
            paradadf Staff @Morikali last edited by
            @morikali as long as you can upload them, you can try if they work regardless of what the webmanager says. Use WinSCP if the webmanager rejects to upload your bios files.
              @morikali the web manager checks the MD5 and the name, that's all, but it may still works with the emulator
              • Morikali
                Hello,
                thank you for all the comments an help.
                Unfortunately when I start games I only see digits an the bottom of the screen. Even after ten minutes I am not able to see any games related screen.
                As a pushed a couple of buttons I was able to see a configuration menu where I could set different settings. Is it necessary to configure something in this special menu ?
                BR
                  @morikali no you should not touch things in this menu.
                  Seeing the digits is a first step, do they move ?
                  Did you try only one game ?
                  • Morikali
                    I am sorry for the late reply.
                    About you questions: Yes the digits are moving for every game I tested (around 5 games).
                    BR
                      @morikali So if they are moving and not cyclically (like moving 13/40/13/40/13/40 etc...) it should mean it is loading, wait for them not moving anymore, so games can take up to 2/3 minutes to launch
                      try Rick Dangerous 1 or 2, they are no too long to load
