    A couple of problems with USB controllers
    GamePad/GPIO/USB encoder
    couple usb
    2340
    • deeimoos
      deeimoos last edited by
      Hi everyone,
      I just finished setting up my Recalbox on a Pi3. I have 2 different problems with my USB controllers:
      For reference, I'm using the controllers you can see here: link text
      It's the version with 2 separate boards and 2 USB cables, the right one to be used with Recalbox in theory.
      1. I'm absolutely sure there's a very easy solution to this, but I can't seem to find it: Recalbox autonomously decided that my left hand side controller is player 2, while I want it to be player one, and of course the right hand side controller should be player 2. In the menu I tried several times to invert the controllers (Recalbox recognizes them as 1 and 0, plus a long name after it) but it's always the same.
      For the rest, in game everything's absolutely perfect.
      1. in Kodi (Recalbox's kody, not another boot), and only inside Kodi, sometimes (but not always!) the controller goes completely crazy, as if I was smashing the buttons while moving the joystick randomly. If it was an hardware problem I'd have trouble in Recalbox too, but it's only inside Kodi.
      I haven't found anything about those problems with google, hopefully you guys can help me.
      Thanks in advance!
      • fabtor
        fabtor last edited by
        Hello try to inverse the two USB cable on the pi3.
        deeimoos 1 Reply Last reply Reply Quote 0
          Are you using the virtualgamepad on your smartphone ?
          deeimoos 2 Replies Last reply Reply Quote 0
          • deeimoos
            deeimoos @fabtor last edited by
            @fabtor I was actually tempted to do that but since they're on a 7 ports active USB hub I thought it wouldnt' work... nonetheless I'll try, thanks!
            • deeimoos
              deeimoos @Substring last edited by
              @substring Nope, just the 2 USB gamepads
              • deeimoos
                @substring that actually did work, thanks! The problem in kodi persists tho...
                  Substring @deeimoos last edited by
                  @deeimoos what worked ?
