    ShanWan Controller Configuration - 3.3.0B6 [Resolved]
    GamePad/GPIO/USB encoder
    shanwan 3.3.0b6 [resolved]
    • astro14
      astro14 last edited by
      I've recently upgraded to 3.3.0B6 and can not get my controllers recognized by the system.  They worked great both wired and wireless with 3.2.X.  When I connect it, it looks to be recognized by the OS.  However EmulationStation doesn't see it as a controller and the sixad process looks like it fails also when I disconnect the cable.  Any troubleshooting steps would be appreciated.
      Sep 18 01:38:40 RECALBOX user.info kernel: [  369.283027] usb 1-1.3: new full-speed USB device number 9 using dwc_otg Sep 18 01:38:40 RECALBOX user.info kernel: [369.398968] usb 1-1.3: New USB device found, idVendor=054c, idProduct=0268 Sep 18 01:38:40 RECALBOX user.info kernel: [369.398990] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 Sep 18 01:38:40 RECALBOX user.info kernel: [369.399014] usb 1-1.3: Product: PLAYSTATION(R)3 Controller Sep 18 01:38:40 RECALBOX user.info kernel: [369.399026] usb 1-1.3: Manufacturer: ShanWan Sep 18 01:38:40 RECALBOX user.info kernel: [369.470694] input: ShanWan PLAYSTATION(R)3 Controller as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:054C:0268.0005/input/input3 Sep 18 01:38:40 RECALBOX user.info kernel: [369.472006] sony 0003:054C:0268.0005: input,hiddev0,hidraw2: USB HID v1.10 Joystick [ShanWan PLAYSTATION(R)3 Controller] on usb-bcm2708_usb-1.3/input0 Sep 18 01:38:43 RECALBOX daemon.info ntpd[323]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized Sep 18 01:42:13 RECALBOX user.info kernel: [582.072604] usb 1-1.3: USB disconnect, device number 9 Sep 18 01:43:00 RECALBOX daemon.err sixad-bin[216]: unable to connect to sdp session Sep 18 01:43:40 RECALBOX daemon.err sixad-bin[216]: unable to connect to sdp session Sep 18 01:43:40 RECALBOX daemon.err sixad-bin[216]: HID create error 115 (Operation now in progress)
      • astro14
        I posted without being through in my research.  I found that if you go into the recalbox.conf file, there is an option for PS3 compatibility.  The default option is set for 'original'.  I changed this to 'shanwan' and was able to register the devices via bluetooth and then set them up as regular controllers.
