    No sound in games, works only in the emulation station
    sound station
    3963
    • Lendário
      Lendário last edited by
      Hello.
      I got no sound in games all of a sudden. The sound plays fine during boot and in emulation station, but it goes silent in games in all emulators. Was working fine yesterday!
      RPI3 model b, latest stable version of recalbox, sound through HDMI on TV.
        Substring @Lendário last edited by
        @lendário no idea ... The splash video can't be used as a reference. But if you have sound in ES, you should have sound in emulators.
        Lendário 1 Reply Last reply Reply Quote 0
        • Lendário
          Lendário @Substring last edited by
          @substring Well, if you don't know i guess i'm screwed. But, if it helps, it happened after i fixed another problem. I had the yellow squares thing in place of the fonts for FPS, save states etc. I found the fix in the forum, edited it into the config file, problem solved. I didn't change anything else on that file through.
            @lendário which customizations have ypu made to the cfg file ?
            • Lendário
              @substring I just did what this post from another topic said to fix the yellow squares thing, nothing more.
              "If you see yellow squares at the bottom then this means that Retroarch isn't loading a font.
              You likely don't need to delete anything, just navigate to your Retroarch Config here: /recalbox/share/system/configs/retroarch/retroarchcustom.cfg
              Then add this line to the Config: video_font_path = /storage/assets/xmb/retroactive/font.ttf"
                @lendário this line is wrong there is no /storage on recalbox. That's an excerpt from lakka. Better check the RA cfg file in the share_init, or retroarchcustom.cfg.origin in the folder of your files
