    Font issue
    font issue
    • rocketbomb
      rocketbomb last edited by
      I am seeing yellow squares instead of yellow english fonts since i upgraded from 4.0.1 to 17... now to 18... same problem. any ideas to fix the problem?
        Substring @rocketbomb last edited by
        @rocketbomb are you using a custom retroarch config file ?
        • rocketbomb
          yes i had custom configs for all emus and have them disabled in current recalbox.conf , i see text only in FBA emulator.
            @rocketbomb then use the search function, you need to add a video_font_path or something like this in RA cfg files. This has been explained a few times.
            For your information, if you like tweaking everything : https://github.com/recalbox/recalbox-os/wiki/How-to-use-custom-config-for-emulators-(EN)#manual-editing
            • rocketbomb
              thanks, after adding video font path location and deleting custom config in recalbox.conf which i forgot before, now i can see the text in all emus
