    [Solved]Problems with Bluetooth Dongle
    bluetooth dongle
    • proto520
      proto520 last edited by
      Hello everyone, I am having quite some issues trying to use a Bluetooth Dongle with Recalbox. My setup: - Raspberry Pi 1 Model B - NES30 Controller - Asus USB-BT400 Bluetooth Adapter - RecalboxOS-v3.2.11 - 16 GB Class 10 SD card   Using the NES30 with the USB cable works like a charm. However, I'd like to connect the controller using the Bluetooth Stick. I tried to follow the manual (https://github.com/digitalLumberjack/recalbox-os/wiki/Manual-(EN)#btcontrollers) to add the controller, BUT the option shown in the screenshot "Pair a bluetooth controller" is NOT shown in my Recalbox UI. Why is that? Is the Bluetooth stick not recognized by the system? Did I do something wrong while following the installation instructions (http://www.recalbox.com/diyrecalbox)? Could you please provide me some help? Thanks in advance. Best regards Proto
      • digitaLumberjack
        Hi, install recalbox 3.3.0 beta.
        • proto520
          Awesome! Thank you for the very quick response. I installed the version you mentioned above. It works perfectly. Thanks a lot for the great support!!! Cheers!
          • colking
            colking last edited by
            I'm trying to pair a wii u pro remote with rasp pi 2 using Asus bt400 Bluetooth dongle but no controllers found. Is there something I can do? Thanks
