    PSP Emulator
    Emulator Arcade/PC/Console
    psp
    • TiagoAssun
      TiagoAssun last edited by
      In the latest version of RecalBox the PSP emulator has been retired? Well I downloaded the 17.12.02 release and the PSP emulator does not appear along with the other emulator folders.
        OyyoDams Staff @TiagoAssun last edited by
        @tiagoassun first of all, it's better if you begin with Hi
        Then, it's even better if you can tell us what is your hardware... How can we help you if you don't give us any information ?
        Because no, the PSP emulator has never been retired.
        TiagoAssun 1 Reply Last reply Reply Quote 0
        • TiagoAssun
          TiagoAssun @OyyoDams last edited by TiagoAssun
          @oyyodams Good Morning. I'm using Recalbox on Raspberry Pi 3 Model B. And a sandisk 32gb sd card class 10.
            @tiagoassun ok I was asking because of that: https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
            As you can see, PSP emulator is enabled on RPI3. It doesn't work very well with all games because of the limited performances of the RPI3, but you can use it.
            So, you say you don't have the psp folder in your roms folder, right ?
            Can you make a support archive ?
            For that, with your web browser on your computer, go to the web interface of Recalbox (http://recalbox/), support section, and launch the support script. Then paste the link here.
            • TiagoAssun
              @oyyodams At that moment I'm at work, when I leave and get home I do it and I'll put it here. Thank you very much.
