    Discrete volume menu popping up
    Emulator Arcade/PC/Console
    discrete volume popping
    • Jonah
      Jonah last edited by Jonah
      Hi, I was wondering if anyone can help me. I noticed while playing MAME 2003 games when I accidently hit the circle and triangle and down on the controller a menu would appear at the bottom of the screen displaying discrete volume, brightness, Qsound etc., pressing the same button combination removed it. Is there any way to disable this, as it's becoming annoying. I've tried through Recalbox by way of the Retroarch menu, and also the menu through MAME to disable it but I can't seem to find a way to do it. P.S. I'm new to this, apologies beforehand if this is a simple issue, I just can't seem to find any help when using Google. Thanks.
        Substring @Jonah last edited by
        @jonah i've always wondered which combo triggered that annoying menu lol
        And can't tell you, sadly
        Jonah 1 Reply Last reply Reply Quote 0
        • Jonah
          Jonah @Substring last edited by
          @substring Oh well, that's disappointing. Thanks for the prompt reply.
