    Installing Beta Procedure
    installing beta procedure
    2099
    • 0n1wheel
      0n1wheel last edited by
      What is the beta install procedure? Do I have to format the card and loose all the roms I have on there?
      • lordtaki
        lordtaki last edited by
        Yes you have to make a full install. Last time I was told it will be the same for the stable release anyway. It won't be possible as far as know to go from 3.2.11 to 3.3.0 via the regular update procedure from the system menu.
        • ivwshane
          ivwshane last edited by
          Is there no way to update via ssh or winscp and copy the files over manually? I have 32GB of files and a super slow card reader so if I can avoid having to recopy all the files that would be nice.
            Nope sorry, there too many changes between 3.2.11 and 3.3.0. So, there is no available update....
            • ivwshane
              But when it comes out of beta people will be able to do the auto update from 3.2.1 right?
                Unfortunately, nope...
