    Can't update
    cant update
    10372
    • Lendário
      Lendário last edited by
      Hello.
      It's been a couple months since i last used my Pi and i see there's a new update but, when i hit start update, it says "No update available" but my version is 4.0.2 still. How can i fix this?
      Sorry if my English is bad.
        OyyoDams Staff @Lendário last edited by
        @lendário Hi,
        Please connect to the web interface of Recalbox with your browser, go to support, make a support archive, and paste the link here.
        Lendário 1 Reply Last reply Reply Quote 1
        • Lendário
          Lendário @OyyoDams last edited by
          @oyyodams You mean the page it goes to when you put the recalbox ip in the browser? I'm there, but there's no "Support" option. Only monitoring, configuration, bios, roms, logs and links.
            OyyoDams Staff @Lendário last edited by OyyoDams
            @lendário ok that might be not available in your old version.
            Well let's try another method:
            • Connect through ssh
            • Write bash -x /recalbox/scripts/upgrade/recalbox-upgrade.sh canupgrade and hit enter
            Cut/paste the result here between 3 simple backquotes:
            your result
            Thanks
            • Lendário
              @oyyodams Putty is only giving me this
              bash: /recalbox/scripts/upgrade/recalbox-upgrade.sh: No such file or directory
                @lendário and with bash -x /recalbox/scripts/recalbox-upgrade.sh canupgrade ?
                Lendário tommymsw 2 Replies Last reply Reply Quote 0
                • Lendário
                  @oyyodams Now it's this
                  + recalboxupdateurl=http://archive.recalbox.com/updates/v1.0
                  + systemsetting='python /usr/lib/python2.7/site-packages/configgen/settings/recalboxSettings.pyc'
                  ++ cat /recalbox/recalbox.arch
                  + arch=rpi3
                  ++ python /usr/lib/python2.7/site-packages/configgen/settings/recalboxSettings.pyc -command load -key updates.type
                  + updatetype=unstable
                  + test unstable = beta
                  + mkdir -p /recalbox/share/system/upgrade
                  + wget http://archive.recalbox.com/updates/v1.0/unstable/rpi3/boot.tar.xz -O /recalbox/share/system/upgrade/boot.tar.xz.part
                  --2018-01-26 21:00:46--  http://archive.recalbox.com/updates/v1.0/unstable/rpi3/boot.tar.xz
                  Resolving archive.recalbox.com... 163.172.161.187, 51.15.211.195, 163.172.153.70, ...
                  Connecting to archive.recalbox.com|163.172.161.187|:80... connected.
                  HTTP request sent, awaiting response... 404 Not Found
                  2018-01-26 21:00:47 ERROR 404: Not Found.
                  + exit 1
                    @lendário said in Can't update:
                    updatetype=unstable
                    Edit your recalbox.conf and set updates.type=stable
                    Lendário 1 Reply Last reply Reply Quote 0
                    • Lendário
                      @oyyodams D**n, it's working now.
                      I tried all options before, stable, unstable, beta and it didn't work. I guess it wasn't updating the config file or something when i was changing.
                      • tommymsw
                        tommymsw @OyyoDams last edited by tommymsw
                        @oyyodams I get:
                        ++ python /usr/lib/python2.7/site-packages/configgen/settings/recalboxSettings.p yc -command load -key updates.type
                        • updatetype=
                        • test '' = beta
                        • mkdir -p /recalbox/share/system/upgrade
                        I see "type" is missing, but it shows right on my .config file:
                        updates.enabled=1
                        wifi.enabled=0
                        audio.bgmusic=1
                        audio.device=jack
                        audio.volume=100
                        controllers.gpio.enabled=1
                        system.hostname=Game_Table
                        wifi.key=mysiswill2
                        wifi.ssid=mine2
                        kodi.atstartup=0
                        kodi.enabled=1
                        kodi.xbutton=0
                        update.type=stable
                        OyyoDams Quemandoacromo 2 Replies Last reply Reply Quote 0
                          OyyoDams Staff @tommymsw last edited by
                          @tommymsw please reinstall Recalbox.
                          • Quemandoacromo
                            Quemandoacromo @tommymsw last edited by
                            @tommymsw Backup folder roms (/share/roms) and make a fresh install,that should fix all the problems 😉
                            @OyyoDams I think there are problems updating if you come from old versions
                              OyyoDams Staff @Quemandoacromo last edited by
                              @quemandoacromo it's because it's a very old and beta version.
                              • tommymsw
                                Dang. But thank you all for the responses. At least I know I HAVE to reinstall.
