    Potential Audio Beneficial Audio Change
    potential audio upgrade
    • dh04000
      dh04000 last edited by dh04000
      Hello Recalbox devs and users. I have a potential config.txt change that may benefit the project.
      I have noticed white noise coming from my sound system with Recalbox for awhile now. I don't hear it when game music or sounds is playing, but I DO hear it when gameplay goes silent. I thought maybe the issue was my shodding electrically work and soldering in my amplifier and have mostly written it off......
      BUT, it turns out that I'm not the only one to experience this problem. See Link (https://github.com/raspberrypi/firmware/issues/380) Turns out that this is a known issue. By simply putting "disable_audio_dither=1" into your /boot/config.txt file, it seems to solve this problem.
      I would like some feed back from the Recalbox devs and some users about making this change default in the Recalbox project's /boot/config.txt file. The best way to test this is to fire up a quiet game like "Super Mario Land" for the gameboy and listen for the white noise. Then make the config.txt change, and compare. Seems 100% cured of white noise.
      • dh04000
        Messed up the title, and now can't change it due to being labeled as spam. Oh well. The correct title should read as something more informative, like "Config Change to Remove White Noise".
        @Substring @rockaddicted
        • Maldorhan
          Maldorhan last edited by
          The white noise you talk about on the Rpi3 is only when using the 3.5 jack output right? I've noticed it too but it doesnt occur with audio through HDMI, thought it would be useful to some readers to point that out 😉
          RPi0W / Retroflag GPi CASE
          RPi3B+ / Retroflag SUPERPi CASE-J
          Retroflag NESPi CASE v1
          dh04000 1 Reply Last reply Reply Quote 0
          • dh04000
            dh04000 @Maldorhan last edited by dh04000
            @maldorhan said in Potential Audio Beneficial Audio Change:
            Yes, you are correct. RPi3 and audio jack. Good catch. 🙂
