    Mame is forcing Player 2 to use Player 1 controls
    Emulator Arcade/PC/Console
    mame forcing player controls
    • apsteven
      apsteven last edited by
      Hi All,
      I have Recalbox release 17.12.02 installed on a PI3 with Xin-Mo (18 pin) controller, using a joystick and 6 butons for P1 and the same for P2..
      Both controller appears to be working, but I have a problem that Mame appears to be defaulting to the P1 inputs even when P2 is playing.
      For instance in Galaxians I have the P2 LEFT input set as "d or RetroPad2 Left", but when it is P2's turn they are forced to use the P1 controls.
      I have noticed that if I use the Dip Switch settings to set the Cabinet type to "C**ktail" rather than "Upright" it will let me use the P2 controls for P2.
      Any help or suggestions on how to enable the 2 sets of controls in Upright mode would be appreciated.
      Steven
      apsteven 1 Reply Last reply Reply Quote 0
      • apsteven
        apsteven @apsteven last edited by
        Hi again
        I think I have figured out the problem for myself.
        By pure chance (and the fact that I was looking at the older 1979-1981 games), each of the Mame ROMs I tried while setting up Recalbox only ever had a single set of controls.
        Although the TAB menu includes and allows modification of P2 controls these are only for use when the DIP switch settings are for a C**ktail cabinet.
        Looks like on earlier games I have to live with using a single set of controls!
        Steven
        101.4k
