    SSH stopped working after updating to ver.17.12.01
    ssh stopped updating ver.17.12.01
    • smp
      smp last edited by
      I get "ssh: connect to host 192.168.1.3 port 22: Connection refused". I use RPi3. Any ideas?
      OyyoDams 1 Reply Last reply Reply Quote 1
        OyyoDams Staff @smp last edited by
        @smp Hi, nothing has been changed on ssh during the update. To the issue is elsewhere on your side.
        • Are you sure ssh is still enabled (check in options) ?
        • Are you sure the IP is still this one (maybe your DHCP server has attributed a new one) ?
        • smp
          smp last edited by
          In options I don't see anything regarding SSH. Do I miss something?
          The IP is definitely correct. I can also successfully ping that IP.
          smp 1 Reply Last reply Reply Quote 0
          • smp
            smp @smp last edited by smp
            On the recalbox machine when I press F4 and ALT+F3 I see this:
            --- 192.168.1.100 ping statistics ---
            1 packets transmitted, 0 packets received, 100% packet loss
            PING 192.168.1.100 (192.168.0.100): 56 data bytes
            PING 192.168.1.100 (192.168.0.100): 56 data bytes .....
            So, I changed the IP address of my PC (from which I try to SSH to recalbox) to 192.168.1.100 (it was 192.168.1.2) and SSH worked.
            SSH seem to work only if the IP of the SSH client machine is 192.168.1.100.
              @smp weird, there is no firewall on Recalbox, maybe a bad network configuration on your PC. Netmask is correct ?
