    Solved WIFI issues
    wifi
    • Grahf 0
      Grahf 0 last edited by
      I can add ROMs to my recal box over an ethernet connection just fine. But when I try wifi I have issues. \recalbox fails to connect most of the time. When I can get it to connect by the time I get to smb://recalbox/share/roms/ it tells me the folder doesn't exist (The file or folder smb://recalbox/share/roms does not exist.) and then I cant reach smb://recalbox either. Typing my recalbox IP into a web browser tells me the site can't be reached. Again, with an ethernet connection I have no trouble.
        OyyoDams Staff @Grahf 0 last edited by
        @grahf-0 hi,
        First of all, do you have an real IP when you're connected in wifi ?
        • Grahf 0
          @OyyoDams Recalbox tells me that my IP is 192.168.0.104. I can ping it from my computer.
            @grahf-0 great! Can you connect to this IP with a web browser ? If yes please go to support and make a support archive, then paste the link here.
            • Grahf 0
              @OyyoDams
              Well my wifi is working just fine now.....disregard I guess!! THANKS!
