    Files Transferring Slower
    transferring slower
    • userreddit
      userreddit last edited by userreddit
      I'm running Recalbox on a pi3. I have my computer plugged into ethernet and the pi3 is on wifi. I transferred a rom just now and it took like 30 minutes. It was about 600MB. It completed and I was going to transfer another rom, WinSCP is saying that it will take 3 hours?
      I'm monitoring the pi3 via Manager. Seeing if maybe that something is going on with the hardware. It says that the temp is 43 degrees. The memory seems to be maxed out at 98% with only 9MB free.
      I'm not sure what's going on, but the wifi is obviously working because I'm actively monitoring it via my web browser. I'm also getting like 100mbps with my laptop.
        OyyoDams Staff @userreddit last edited by
        @userreddit internal wifi of rpi3 is bad quality and very slow, you might consider buy a usb wifi dongle.
