    second USB controller not working in emulator
    GamePad/GPIO/USB encoder
    input usb controller buttons arcade buttons
    • gomezl.ivan
      gomezl.ivan last edited by gomezl.ivan
      Hi, After reading many topics regarding how to configure 2 gamepad in the forum, I feel the need to post my own issue here.
      • I got latest recalbox version (17.12.02), I'm using raspberry 3 model b.
      • I'm using 2 arcade joystick from Quimat, using 2 USB controller, with same configuration
      The 2 gamepads are working like a charm in recalbox, but not inside the emulator (neogeo, megadrive, MAME, tested many of them), the buttons in the second player are broken. (but up/down/left/down work), but not (x/y/a/b)
      I've followed this link:
      https://forum.recalbox.com/topic/4630/mapped-2p-buttons-don-t-behave-correctly
      It seems a problem with the USB port, and it proposes adding a custom property in cmdline.txt usbhid.quirks=xxxxx
      This is my lsusb output:
      lsusb
      Bus 001 Device 005: ID 0079:0006
      Bus 001 Device 004: ID 0079:0006
      Bus 001 Device 003: ID 0424:ec00
      Bus 001 Device 002: ID 0424:9514
      Bus 001 Device 001: ID 1d6b:0002
      Does it help? Device 004 and Device005 got the same ID.
      Anyway, I tried to modify the cmdline.txt and configure again the 2 gamepads, but the problem is still there (Probably I'm not doing it correctly )
      I' got the recalbox-support logs, I'll try to attach in the post.
      http://www119.zippyshare.com/v/ylh7egwV/file.html
      it would be nice to know what else can I do to test my 2 gamepads working in the raspberry using latest version of recalbox.
      (I reproduced the same issue in retropie)
      Any help would be very very welcomed.
      100.7k
